Re: [ROM] CleanROM 2.3.SP1 - 9/4/11- GB 2.3.4 - The Smoothest Yet
Okay if it's just the kernel then you need to make a zip with the anykernel method to flash the kernel into the boot.img.
boot.img is actually two parts ramdisk and kernel(also known as zImage)when put together they make a boot.img. There's no commands to flash just a kernel(none im aware of).If your wanting to flash back to the boot.img that came with this rom then it's very easy.
Open the cleanrom.zip,pull the boot.img out of the zip and into the sdk/tools folder then do as i stated above to flash it with fastboot. If all else fails post what you have kernel/boot.img and the files from the system/lib/modules folder too. Ill make a zip to flash it.
It's the kernel from clean rom. I read that boot.img is the file I need to flash it.
