[ROM] 11/20/11 - CleanROM 2.9 - GB 2.3.4 - Perfection Achieved!
Re: [ROM] 11/20/11 - CleanROM 2.9 - GB 2.3.4 - Perfection Achieve
I tried searching through this thread but couldn't find anything related so sorry if this is has already been answered.
I recently installed CleanROM and everything seemed to be working fine but today when using my GPS (both Telenav and Google Nav) there was a considerable lag a lot when updating my location. Everything was working fine pre-flashing and all my other radios seemed to be working so was wondering if anyone had ideas
Just read your post and fired up Google Maps for the first time since flashing CleanROM. It took about three seconds to get an accurate GPS lock on me inside my house -- better than stock.
see, thats one ofthe weird things. I get the lock instantly like you said but when I'm actually driving I get these stutters
First time rooting. Never did this before in my life. Had no problems. Installed this ROM with zero problems at all. I love it. UI seems so much faster. Great stuff.
My question is with ROM updated. I'm seeing under the existing tab a zip that's says stock_battery.zip - what is this? An update for better battery life?
I tried it while I was riding on the DC Metro and had no problems with the GPS updating instantly as we moved. Not sure what might be causing your issues.
It just changes the icons used to display your battery in the status bar.
Ok thanks for clearing that up. Last question from me... Under the ROM tab in the ROM updater there's a kernal. Bcblend. Is this already built into clean Rom or do I flash this seperately. I'm guessing this is overclocking. Is this a good thing to flash? Make a difference?
Thanks!
Ok, so I made the mistake newboyx made back in thread page 7-10.
I followed this guide here:
http://forums.androidcentral.com/ht...oot-install-custom-rom-hboot-1-5-3-steps.html
I don't know that much, but I'm assuming I'm using CWM recovery?
Then I flashed CleaROM 2.9.
Wifi tethering doesn't work.
What do?
I have Evo3d hboot 1.5
Should I revert back to stock than recovery again with TWRP?
Can someone please please please provide me with a step by step specifically for my case?
newboyx? :)
Thank you for your time.
In Wifi Tether, did you go into the Settings and change the device to the EVO 3D and enable the routing fix? Once I did those things it worked for me. :)
Change Device Profile: EVO3D
Setup-Method: Auto
Wifi encryption: yes
Hide SSID: no
Change channel: Auto
Bluetooth: No
Wifi-driver reload: No
Enable Access-Control: Yes
Change LAN: Didnt touch it
MSS clamping: yes
Routing fix: yes
Everything else I didn't touch besides for Disable Wake-Lock: yes, that's checked.
Please halp D;
My laptop can connect to my phone successfully through wifi tether but it says no network access or limited access?
FYI, I do have 4g network on and it picks up 2/3 of the radar-sphere icon.
I flashed clean rom 3.0 a week ago works great much props.
But i just noticed tha camera doesnt work.. i check the known issues in the OP thread at xda but nothing stated about the camera..
Should i reflash the rom ? or is there a fix that i over looked..?
I tried to post this issue in the OP thread for this rom at xda but wouldnt let me reply.. thanks
Evo 3D running CleanRom 3.0
I didn't have any problems with the camera in 3.0 so it is possible something didn't go right when you flashed. You may retry flashing. Another option would be to try the camera hack in this link. I use it and alternate between it and the Amaze hack.
[TEAM XPOSED] [MOD] Remove shutter sound from 2.3.4 HTCCamera.apk - xda-developers
Hope this helps! :D
Reactions: scoot0073
Thanks carrie for yr help.. yea im going to reflash and c if that works.. thanks for the link to..
YES! Wifi Tether WORKS NOW! :D
Problem was the Enable Access Control.
This limits the device from actually connecting to the net even IF it's connected to the phone.
The "Enable Access Control" option appeared after I downloaded:
wifi_tether_v3_1-beta10.apk - android-wifi-tether - WiFi Tether for Root Users 3.1-beta10 *** BETA *** - Wireless Tether for Root Users - Google Project Hosting
Reinstalled through the QR code, connected to phone with laptop through Wifi Tether, and my phone popped up a warning.
I allowed my laptop to connect and now I'm 3G enhanced running at 7Mbps at HOME :D :D
I cant wait until 9000G comes out when we can actually enjoy that 100Mbps speed!
Reactions: CarrieK
@ carrie
I got it fixed.. all i did was clear cache in recovery and my camera works now..
Reactions: CarrieK
I have a bunch of questions that I've been searching for high and low and can't seem to find any answers. Any help or assistance would be MUCH appreciated.
So, I'm completely new to rooting. I've never rooted any phone besides my palm pre. So all of this WAS and still IS terrifying territory.
So I rooted using the thread - Root in 3 easy steps...
I have TWRP installed via those directions.
I rooted using the HTC method.
I'm running clean rom 2.9.5
Now, nowhere in those directions did it mention to make a backup of your system. So I rooted and flashed a rom without making a backup. Is this good or bad? I'm told making a backup is basically taking an image of your system so if anything happens I can just restore that backup image and my phone will go back to the way it was.
So my questions are.
-Is it a bad thing I never made an initial backup of my stock phone prior to flashing cleanrom?
-Can I just make a backup of my phone as it currently is flashed with cleanrom? so if anything happens I can just restore the image and it will take me back to where it currently is with cleanrom?
I want to flash cleanrom 3.0. In the directions on page 1 it says I need to wipe data/factory reset.
What happens when I select Wipe Data/Factory Reset? Does this wipe all my data and do a factory reset of my phone?
Create a backup now.
Ok, now that you are back.
Wipe Data will erase everything.
Some people will do a "dirty flash" by only wiping cache and dalvik cache. This can be done, but Scott always recommends a full wipe. If any bugs do come up, please reflash doing a full wipe prior to reporting it.
Ok. well. I didn't create a backup yet.
What I did do was flash the BCBlend Kernel using Flash Image GUI. Everything was working fine. I wanted to see what overclocking my kernel would look like.
Soon after I decided I wanted to revert back to the stockish CLEANROM 2.9.5. - So I removed Flash Image GUI and SET CPU, and wiped data/did a factory reset. I reflashed Cleanrom 2.9.5 and when it rebooted I no longer had working wifi or 4g.
So I was stumped.
I was running cleanrom 2.9.5 but obviously had some hiccup with the kernel.
So this morning I redownloaded FLASH IMAGE GUI and reflashed the BCBlend kernel and now my wifi and 4g is working again.
All I want to do is go back to stock cleanrom 2.9.5 with the stock kernel with dim lights by mwalt. I don't want this BCBlend kernel any longer.
Any help?
After this I am done messing with my phone. I'm surprised I didn't brick it. You REALLLLLLY have to do something really wrong to brick your damn phone it seems. Because I've been learning as I experiment and have yet to brick my phone.
So yes, any help with my above problem?
Thanks much!
just flash the kernel that comes with CleanROM
Takyi Benedict
