[ROM] - 2/5 - CleanROM 2.3 -=ICS Edition=- Clean and Smooth!
Re: [ROM] - 1/21 - CleanROM 2.1 *Ice Cream Sandwich Edition*
I'm running your SenslessROM 2.0 right now. My question is, which one is better? I'm not a huge fan of Sense UI but I'm willing to deal with it if the ROM works better overall. Appreciate any help :)
Sent from my ADR6425LVW using Tapatalk
I have tried both CleanROM 2.0 ICS and SenselessROM 2.0 ICS, and in my experience CleanROM is more complete, less buggy and according to AnTuTu a better performer. I have not tried CleanROM 2.1 ICS.
Reactions: DbZ Gokuu
Yeah, just flashed CleanROM 2.1 and its absolutely amazing. Virtually no bugs, amazingly fast. Only bad side is Sense (IMHO). Not sure how much better it is than 2.0 tho.
I've been running CleanROM 2.1 ICS and it performs very well averaging 6500 on AnTuTu. The only thing I've noticed is that I cannot stream music over bluetooth
Tried to install Swype but I'm having the same problem as Topher: Under "Settings > Security", there is no option to allow installations from "Unknown Sources".
I did a full data wipe and install, and several reboots....any hints anyone?
I checked and in my Settings > Security there is a checkbox for Unknown Sources.
Re: [ROM] - 1/18 - *CleanICS* - Ice Cream Sandwich 4.0.1 - 99% St
Do not try to set encryption or any other options! Your device will fail to work! If you need these features its time to subscribe to VZW Hotspot!
Does "any other options" really mean "any other options"? Can I at least change the SSID? Does access control work? Are these things a matter of the wifi tether application properly supporting these features; in other words, is it possible that these options will be supported in future updates of the wifi tether app?
More than likely they work but I have not tested nor do I support them.
I'm running CleanROM 2.1 and did a full wipe...gonna try to reinstall and see what's up.
Has anyone else experienced the "gallery app" not picking up all materials on your extSD card? Tried to set the backround wallpaper to a photo i have in my gallery and and it kept giving me an error message.
From reading the above posts, I tried this rom with the newest beta version and the wireless tether (changing device to samsung galaxy nexus CDMA/LTE version and router fix enabled) and the WIFI actually worked for my toshiba thrive android tablet. The rom enabled the wifi tether to be seen as an infrastructure (ap) mode. Before this, only ad hoc was available. I was so excited cause I've been searching for a loop in the wifi tether for a while and it actually worked. The bummer is, in this ROM (at least for me), the camera and gallery are glitchy. The gallery more so then the actual camera app. It won't read the extSD card. I tried unmounting and remounting and trying to get gallery to see it in a round about way opening the photos in File Explorer with gallery and no luck it freezes. The camera on this phone was definately a step up from the TB and can't be lived without. It just seems like you always have to choose one option over the other. ARRRHHGGGGGG Charlie Brown. Good Grief. :o) If the gallery worked with the camera fluidily, this would be my hands down #1 rom. Everything else is awesome and absolutely fast.
I have been using CleanROM 2.1 ICS for several days now, and I have not noticed any problems with the camera or gallery app.
Can this be used on the thunderbolt? Cannot seem to find a good ics rom for thunderbolt.
I got an error when I was messing around with SystemUI.apk but when I put it back to stock it was fine. Anyway I use quickpic now because it blows the doors off the stock gallery. Camera and gallery are probably going to be glitchy until we get a better leak(or the actual final version).
Is there going to be one anytime soon? Gengrvitus is getting old for me. Lol. Thanks!
Do you think there will be a ics rom for thunderbolt anytime soon?
Sorry bro, this is a Rezound thread. If you have questions about the Thunderbolt please go to the appropriate area of AC.
Sent from my HTC Rezound using Tapatalk
Check with the people who Dev ROMS on the Rezound and po0ke around on XDA. I am sure some one is working on one. They did ICS for the Evo 4G and thats near identical to the TBolt, if I am not mistaken.
Never owned a tbolt so I dont really now.
But yeah, I wont be doing one.
** I don't think I touched the SystemUI.apk. What's that and how's it reverted back to stock?
Thanks for the tip about the quickpic app. I just looked it up and seems like lots are saying the same exact thing that you said. A couple have even directly commented about working specifically on Android 4.0 and CPU rendering. ** I'll give that a shot.
Thanks.
Re: [ROM] - 1/25 - CleanROM 2.2 -=ICS Edition=- Tweaked / Tuned /
Version 2.2
REQUIRES: Flashing the new boot.img! No exceptions!
Added: Mild Performance Tweaks
Added: Percent Battery
Added: init.d Support
Added: Galaxy Nexus Ringtones
Added: Camcorder to App Drawer
Rmeoved: More Bloat / Logging
Removed: HTC Stocks
Removed: Google Books
Removed: My Verizon From Staus Bar
Removed: Pen Input
Please hit the Thanks button if you like this offering. Hit the Donate button if you really like it :)
Mama Mia
