[ROM] - 2/5 - CleanROM 2.3 -=ICS Edition=- Clean and Smooth!
Re: [ROM] - 1/25 - CleanROM 2.2 -=ICS Edition=- Tweaked / Tuned /
Friendly warning that there are some issues with CR2.2 . Don't flash it yet please. I'll edit this message after it's all fixed up.
I already flashed it, what kind of issues can I expect?
John
I just wanted to report that I've installed CR2.1, and I am really digging it! Thanks so much for your effort, Scott! :)
Friendly bug report: The Bluetooth seems to connect to the handsfree in my car (both devices report phone and audio connection), but when I play audio, it plays through the phone speaker. Is this something that you would have any control over, or is this more of a driver issue?
There should be an output toggle in whatever music player you're using. Mine does this occasionally on Senseless ICS, and I have to manually change from the phone speaker to whatever bluetooth "headset" I'm using.
Thanks for the reply. But there is no such toggle in the Rhapsody app that I am using. I've never had to select anything within an app for this to work in the past, and I've been using Bluetooth for streaming audio from an Android phone for nearly two years now. It's always just sent all audio through the Bluetooth connection when connected.
If you haven't already, double check. Tap the menu key and look for a setting that say output. Other than that, with rhapsody playing disconnect bluetooth and then reconnect it. Hopefully the phone should realize a stereo device was connected and switch music to it.
Yea, I looked for a setting, but there isn't one. Actually, there's a setting for Bluetooth controls, and interestingly enough, the controls actually work! I can change tracks from the steering wheel control, but no sound. I've also tried other apps, to no avail. The phone part seems to work dine, too. I can make calls. Just no music/audio.
Re: [ROM] - 1/21 - CleanROM 2.1 *Ice Cream Sandwich Edition*
Just did a re-install, and added the Dalvik cache wipe, and was able to see the "Unknown Sources" option and checked it right after the reboot.
But in the course of adding accounts (gmail, google, google backup), the option has now disappeared even though it is still set to allow unknown sources.
Hope this helps....
With my car's aftermarket radio it connects as two different devices. Might be worth it to go into the system settings bluetooth menu and check to see if it's connected for both hands-free AND media audio.
I'm noticed the exsct same problem. I noticed that when I pair my phone to my car it say "connected " then it say "no media "
Sent from my HTC Rezound using Tapatalk
CleanROM 2.1 Service Pack 1 is up!
This fixes the weird FC's!
Sorry about that guys :'(
But its good now!
Installed CleanROM 2.2 last night, and its running very smooth. All my apps except one load and run as expected. But still no love when it comes to streaming audio over bluetooth. I try to stream Pandora to my Elantra's car stereo and it still does not work. When I pair the phone to my car, it connects but also says "No Media". Any fix for that?
FYI, I had the same problem with CleanROM (although everything else worked great). I just tried out Senseless this morning, and found that the Bluetooth does work correctly. And since they are from the same leaked source, I have to assume that this is fixable in CleanROM. It may have something to do with Sense, since that is obviously stripped out of Senseless.
Thats good to know, I tried Senseless and liked it but I thought it was alot more buggy than CleanROM. The problem with media streaming over bluetooth is really the only issue I have with CleanROM and though I would like for it to work, it really not that big a deal.
Yea, there's a glitch here and there, but Senseless really seems pretty darn stable to me. On top of that, it does seem to use less battery, which is important to me seeing how fast this thing can chew through a full charge! I'd say that's the only real downside I can find to this hardware is the putrid battery life, but that's a common problem with Android devices, and I'm used to it by now.
I use Bluetooth in my car almost daily, and also for a set of Bluetooth headphones when I'm working out, so that's a big one for me. I hope Scott can get that squared away on CleanROM, so I can have that as an option. Either way, I've extremely happy with my new purchase. It's leaps and bounds ahead of my Bionic, in my opinion. It's more comfortable to hold, and to talk on (the sharp edges of the Bionic are so uncomfortable), the camera is just plain impressive, as is the screen. The speaker is louder. Even the antenna seems to be a step up, as I am getting higher average speed tests, and at least getting a somewhat usable 3g signal at my office, whereas I got zero signal on my Bionic (and I kept reading how Motorolas have the best antennas). And of course with the unlocked bootloader, we've got the magic of custom ROMs like these two beauties that Scott has whipped up! Yea, I'm a very happy Android nerd right now! :D
Okay, so I jumped the gun a little on reporting proper Bluetooth streaming with Senseless. It turns out that it worked for me the first couple of times, and now it's giving me the same type of trouble that CleanROM was giving me. It'll say it's connected, but then play audio through the phone speaker. A couple of times yesterday if I turned the Bluetooth media connection off on the phone, and back on, it would pick up the stream, but I tried about 10 times today and it never properly connected.
When i click on a bookmark it just refreshs the current page it never changes. My verizon doesnt work and when i press after being on the internet it refreshs sence. Does this happen to anybody else?
That's weird on the bluetooth. I stream every time I'm in my car and my radio gives me more problems than my phone does.
Im using clock work recovery to flash the Rom, since thats what im used to coming from a droid x. everything flashed, but the boot.img failed. any help? im stuck. Bootloader menu wont let me chose any options on startup. Does anyone have a boot.img file i can use and where does it need to be on my memory card?
Mama Mia
