You didn't try the babystep?
Sent by a little green robot
I find it funny everybody is doing it in the opposite order Hero suggests and then talks about the instability. Baby Step first - Step Two second - ultimate third.
Just FYI, ultimate only lasted about 10 minutes before I gave up after 3 freezes. Tried step 2 today. Worked great all day until I made a phone call. When the screen would go off for proximately, couldn't get it back on. Had to battery pull, then reboot. Tried again 3 more times, same result.
Gave up and flashed back to acs rom with extreme kernel. I wanted to give the new baked snack a shot, but I value stability as top priority (if not, I would give the froyo rom a shot). I'll try out the new acs rom tonight.
Nah, figured once I get down to the 3rd best kernel, I'm not really gaining much (if anything) vs. extreme kernel. I like playing around with these roms and kernels a bit, but I don't have enough time or patience once I got past a few steps. Also, now that hero is off xda and the downloads are not on his site, there's no support anymore for fixing bugs. ACS has a new rom out tonight, and their developers practically live on XDA. Solutions may go over my head a bit, but they've always tried to help.
With froyo coming out and the roms and kernels changing daily, I value stability first, knowing that there will probably be 2-3 updates on roms or kernels this weekend anyway.
How do I disable the ad blocker in this rom? Having it on is keeping audiogalaxy from working.
anyone have a vanilla lock screen that works with 1.6 and confirmed? thanks
Sorry, no idea on that one. You might try contacting the dev on his website bakedsnackshack.com
Go here and download the link next to
"Here's a .zip that has both the AOSP lockscreen mod and reboot button mod together:"
If you flash just the vanilla lock screen, it takes away reboot on the power down menu. This one however retains it.
thank you for that, also, if i dont like it, , how do i go back to the one i have now (that came with 1.6)?
did it ever occur to you that maybe people only gave it a shot to use the ultimate kernel for battery?
thats why i gave it a shot. i decided if ultimate does not work then i dont really care for it. acs has been too supportive and so professional that i prefer them over any other rom
Uh did it occur to you that the battery difference is negligible between all the steps? Which is why he suggests a progression, even the worksforall Bakedsnack has nearly double the batt life of ACS currently. ACS is not near as smooth as Bakedsnack either, currently the only improvement I see in the ACS rom is higher benchmark scores and more active support. Those scores definitely do not translate to smooth consistent operation within the ROMS.
Regardless of the reasoning for trying things in the complete opposite order of the Dev's suggestion, it is still comical when there are complaints about it. Glad you like the ACS though, my wife is running it on her Epic.
well when the dev says "ultimate has extremely good battery life - step 2 has pretty damn good battery life - baby works for everyone"
then of course im going to go straight for ultimate.
to me, i think he is saying try in order because they are buggy for certain people. it has nothing to do with checking the battery comparison or anything like that. its simply some phones are not compatible with those kernels.
and i think acs is pretty smooth. do you mind elaborating?
in fact i think nearly all the roms are smooth. hell even the stock is smooth. so please expand.
as far as battery i dont care too much because im usually on a computer and i use my phone for its sd card to store all my drafting and computer stuff.
EDIT: CHANGE YOUR SIGNATURE FOR JOINING THE DARK SIDE!!! HAHA JK
