[ROM] Android Open Kang Project- Jelly Bean Style
Oh and can someone update the front page with the newly posted nightly or one of the mirrors since their server is getting destroyed at the moment ;)
Someone on Rootz claims any SHOULD work
The 7/26 gapps on the first post in this thread is going super slow. Anyone got a mirror to them? I want everything saved and ready for me to flash tomorrow after work :D
There will be a mirror ill post in 5 minutes, I try to do it for every build for the late night downloaders.
Thanks man! Guess I will just call it a night then. Dload will probably be easier tomorrow when everyone is not rushing to get gapps and the first nightly
Goo seems to be downloading gapps 7/26 fairly quick
I have 2 different GAPPS here, I have the 7/23 AOKP GAPPS and the 7-26 CM10 GAPPS. I wonder if one is better/different from the other. The last GAPPS i actually used was 7-17 :eek:
Also i was told that at some point the GAPPS were updated to the actual JB apps, But i have no idea when or what package this includes.
SVFD, can you report what GAPPS you used and if auto restore worked?
Maybe this will help. ;)
https://www.dropbox.com/s/al0yr91rulk6iat/aokp_toro_jb-0729.zip
MD5 for Nightly 1: e831d9bf9e7c3583d58b81f1dea4d8eb
Also here is the 7-23 AOKP GAPPS. The 7-26 CM10 will take 10 to upload.
https://www.dropbox.com/s/0oma8yb8krt8y86/aokp-gapps-0723.zip
All credit goes to Roman and the AOKP team.
Should it make any difference if I use the CM10 Gapps (linked on the front page) over the AOKP 7-23 Gapps? Was able to get the CM10 ones to download.
Flashing now. Will report back in a few....
Im trying to figure that out now. I have like 10 GAPPS packages on my phone/computer. Kejar/CM10/AOKP. The Gapps are more confusing then the ROM downloads since alot of them are interchangeable. If i find out ill report back.
If you go by the original post on the Rootz thread the updated GAPPS are the 7-23 AOKP. Since the OP on Rootz recommends those i would use those myself. I know the OP here lists the 7-26 CM10 zip, In theory they should all work.
Reactions: VAVA Mk2
Cool thanks! Just to be safe, I downloaded the AOKP Gapps. Can you give me a link to your post on Rootz or do you have the MD5 Sum for the 7/23 AOKP Gapps? Want to do a quick hash check for the MD5 Sum before I call it a night. You rock, by the way! Very helpful!
HushRA
