[ROM] Android Open Kang Project- Jelly Bean Style
This might put the brakes on me flashing tonight, i need my GPS tomorrow.
Did you go rebel and dirty flash or start fresh and wipe?
Wiped everything but did not do a factory reset. I haven't had a good lock on gps since I left jelly belly for Preview 1.
From what I understand it is simply a polished Preview 7. This is the first nightly build.
Any change log yet? or is there no change from 7? Just tweaks and stability maybe?
If your GPS has not worked since P1 might be time for a full wipe, P3 GPS works fine for me. Might be an install issue.
@Droid Evo,
All the info/downloads you need for Nightly 1 should be on the previous page (13). All local mirrors will remain up till the next build.
Reactions: Droid_Evo_8
@Droid Evo,
Ok, thanx
@Droid Evo,
Just got done clean flashing. Auto restore works well as does TiBU. Hoping this fixes GPS
Well that didn't work. Guess I'm just not where I think I am.... I mean, smartphones are WAY smarter than I am, right?
What Gapps did you go with?
Also what didn't work? GPS?
There's some reports of screenshots not working on Preview 7, I just noticed that was the case for me too, how are the rest of you guys doing?
I see it working for lpt2569, nice.
Working for me. I did a complete wipe coming from Jelly Bro though.
GPS worked fine for me on both Build 1 and Preview 7; used it extensively, even throughout areas with no signal.
GAPPs flashed = 7/23 package.
Reactions: kca2000
Where are these themed icons stored on the phone? Does anyone know?
If I remember correctly, I *think* someone once told me on here that if you extract the APK for the theme, then change the extension to .zip (instead of .apk) and extract the files, there's a "drawable" folder where the icons are stored. Not sure if that's all accurate, though.
Anyway, decided to flash the 7/29 AOKP build. I guess they don't yet have lock screen customization, huh? D'oh. And I was so used to it finally working on JellyBro. Ah well, guess I'll have to wait a little longer for that again. I hope they make the notification light easy to customize, too; I really loved the way JellyBro allowed you to customize it, it was so simple and easy to do. Trinity still a good kernel to use, or should I look at something else, for AOKP?
camran
