[ROM] Android Open Kang Project- Jelly Bean Style
Let me know your thoughts and impressions! Can always flash tomorrow lol
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
Did you turn in your crackflashers' membership card? ;)
Sent from my Jelly Bean-equipped Galaxy Nexus
Lol for tonight, yes. That and the Skank is legit faster and I'm enjoying the polish lol.
Not noticing anything crazy new. Themes are there, but i expected that. Auto restore worked again with aokp gapps. Seems more polished. Glow is back on the nav bar. GPS is locking me faster as well. Everything ive tried so far works. Remember im coming from P3, so some of the stuff im noticing may have been around for awhile.
I came from P7. The changes I have noticed so far are navigation bar transparency, new battery icon setting and the color settings are now active. They have presets as well, so you can get the CM look (think Trinity) without needing to flash the kernel, which helps in trying out the stock kernel longer.
I still don't see lockscreen shortcuts. I thought I read that they were now included. That's one of the features I miss from CM10.
Can we dirty from 7/29 build or is clean wipe required
I DF from P7. Working without a hitch for me. I wiped before P7, coming from Euroskank.
I tried to dirty flash from 7/29, but it didn't play nice with my installed apps. So wound up wiping completely.
Can you alter the soft key colors yet? Or brightness? That'll complete me lol.
Love the toggles on CM10. Can't get over the transparent look. Great great touch.
Is it me or is aokp jb on a diet? I'm not seeing much butter here...its noticeably laggy with stock kernel and a dirty flash from 7/29 build.... but even then, after a clean flash, 7/29 wasn't as slick as even jelly belly 3.x
what gapps are we suppose to install? in op there is a link to goo and a link for 7-17 signed.
is there a AOKP gapps we are suppose to use?
Yes it's not as fluid as others, but gee golly Iove that navigation bar.
No colors yet. The transparency should be called brightness since there is just black behind it.
Ahhh, so all it does is increase the brightness and such (really). Forgot about that feature from AOKP of months past :).
I also am having an md5 mismatch. The file generated: 45b1577d1a01a1a878f3f1a4ccc3c016
I am just going to install anyways... see what happens. I can always restore my backup if it messes up :P
I tried to think of something witty, but this is all I could come up with.
I'm also noticing notoriously bad battery life on AOKP. CM10 seemed to be giving me the best battery life. I have been running some tests with Bad Ass Battery (hate the new name), and I'm finding little to no apps causing the issue. Wake locks are pretty normal. I did notice Slice was taking up a lot of battery and so was Tapatalk. But even after FCing those apps, the battery seems to be pretty bad.
Alas, I might have to make a nandroid backup of this ROM and revert back to my CM 10 backup.
criteriascenario
