[ROM] Android Open Kang Project- Jelly Bean Style
I saw the hints on Twitter about a milestone today. It figures since I finally got around to flashing b5 yesterday. :D
Sent from my Galaxy Nexus
Anyone know if group texting will be added?,.......Never mind, "group MMS" mentioned above, must be more hungover than I thought!
Still not officially merged.
I cherry picked that feature.
Anyone who knows what's up...
Milestone+ will be up whenever Milestone drops.
Flashed M1...SystemUI crashes consistently when I set the Clock short press option to Alarms. Does not crash on grouper. Both clean flashes.
Eh, i'll take it.
Comes packed with Lean Kernel. Hopefully faux gives up kernel deving now b/c of this :p
Eh, i'll take it.
Same here, I haven't had any other bugs so far ..so I guess that's acceptable:D
Installed in on Grouper with no problems.... I will wait still on Toro. I'm still very satisfied with Jellybro.
Haven't used it, but it wouldn't shock me if the hurricane was messing with GPS for most of America ATM.
FWIW, my GPS was wildly off. Chalking it up to Sandy, just like the massive storm affected the GPS back in June/July.
Come on AOKP, Milestone release and I still can't use Google Play Movies app. :-(
Eh, i'll take it.
New Franco nightly 298 has the NOOP I/O Scheduler. Before the only options you had were Deadline and CFQ.
Alright, Question here. Anyone know if 4.2 changes can/will be merged with the current AOKP ROM? Or is the team going to have to start from scratch again?
They will merge it, not start from scratch :)
EDIT: Although I'm not positive about certain features.. For example the pull down toggles aren't needed as much with the quick settings in 4.2 so they might change/redo the style for them, or integrate more options into the new built in ones.
Just clean flashed to M1, no issues. But does the AOKP Backup app work for anyone? When trying to restore I get a "AOKP is not detected" error.
Everyone with M1, can they try the clock thing I described?
Go to Settings, then ROM Control, then Clock. Set "short press" (or whatever the hell the other option is that isn't long press), select "Alarms."
Go to the home screen, pull down the notification drawer, and tap the clock. Force close?
HushRA
