[ROM] CM-10.2 4.3 rom + 3.0x kernel
I will send you a download link for this app I use .
Previous Username: UnrootedDroidOwner
Current Phone: Lg MACH(LS860)
Old phone: Lg Optimus S(LS670) Currently my MC:PE server hoster:)
And soon to come is a Nexus 7 2012:)
Can you private message me the link ? Thank You !
Yep. Sure will. Just a few minutes. Its been a great while since I used it.
Ok. Found the original thread on XDA Dev's. http://forum.xda-developers.com/showthread.php?t=2086361 Just follow the instructions. Be sure to support JoeyKrim in the play store if you like his app. It take no credit for the app.
Ok. Found the original thread on XDA Dev's. [APP] Flash Image GUI - Flash Kernels and | Droid DNA > XDA Just follow the instructions. Be sure to support JoeyKrim in the play store if you like his app. It take no credit for the app.
I think i flashed it correctly . Do you flash within the app while browsing for twrp ?
Yes. You will find the recovery.img that you download, it will go back, and hit install. And reboot jnto recovery to make sure it worked. WARNING! Twrp recovery isn't compatible with xionia backups. There is a work around which I will post in a few minutes.
I would put it in the root of the SD for easier access.
i tried it but when i reboot to recovery it stays at LG logo or if i manual reboot the screen is lit but black
Hmm. Seeing as my optimus is inoperable ATM due to a lost SD card, I will try something. Back in a few.
Edit: Make sure you are using the correct recovery image for the s.
Aha alright thanks for helping me btw
No problem. That's what I do.
Make sure you are using the correct and latest version of twrp for the Optimus S.
Yeah. I'm going to bed. I will get back to you tomorrow.
Current Phone: Lg Mach (LS860)
Retired: Lg Optimus S (LS670) Currently my MCPE server hoster:)
Give you girls and guys something to play with. CM-10.2 android 4.3.
INSTALL:
  • Full wipe in recovery
  • Install the rom, gapps, virgin fix (if any)
It wouldn't install. At all. It spit back errors concerning the build.prop; seems like it went back and forth between saying LS670 & VM670. Not really sure why that is, though.
I'm not sure. I'm not the expert. Kraven is.(bows in honor of TheKraven). I can't even try it because I lost my sd card.:(
dumpsterrentals89
