[ROM]CM10.1/PAC-rom jb 4.2.2 The JBC alpha build
Here's a 3/9 pac rom build
Fresh PAC-Rom/cm10.1 sync. Fixes custom tiles. They removed hdr camera modes, as our hardware doesn't support it. It might be the last build from me as I lost my Optimus. The code is there for anyone to carry on.
http://goo.im/devs/thekraven/LS670/pac/PAC_JB_4.2.2-v20.1.0_20130309-LS670.zip
thekraven,
If you are not offered an Optimus to carry on your great work, please message me.
ctgova
Is it possible to flash this without having to wipe everything?
That depends. If your switching from a different ROM then you have to wipe everything but sdcard. If your updating the ROM then all you have to wipe is Dalvik-cache and cache.
Sent from my C5155 using Xparent Skyblue Tapatalk 2
I have test build 3 so updating.... So just wipe cache and dalvik cache? But when i wiped dalvik cache it wouldn't read my SD ext and the phone would mess up...
Did you flash any sdext scripts? If yeah then reflash those as well
I did the crons INT2EXT, so just flash the update, wipe cache and dalvik, then flash crons again? Or what order?
Is there a fix for live wallpaper?
Wipe, flash update, flash scripts.
Updating it didn't work. It was on the boot screen for 2 hours. I just decided to wipe everything and flash. Thanks though.
I have to uninstall the ROM] The JBC CM10.1/PAC-rom jb 4.2.2 alpha build to use the cross breeder or not?
Probably due to the location of the dalvik cache. There's a special zip to wipe dalvik when using int2ext scripts it's in cronmod's thread
Tapatalk'n it PAC-Rom style! Android 4.2.2 on my VM670 running LS670ZVJ firmware
I hope you can continue your work on this, thekraven. Your work is outstanding, and you're the last great dev (that I know off) that still works on the LS670/VM670. It would be truly sad if we lost you. The shrinking base of hardcore OS/OV heads would be at a loss, as that would be a dark day for us indeed.
No need to uninstall. You can flash CrossBreeder at any time. The only extra thing you would need to do is delete all Seeder files if you have that installed.
Sent from my ZombieBean-VM670 using Xparent Blue Tapatalk 2
Live wallpapers downloaded from the play store work fine. I'm guessing the standard live wallpapers were deleted to make the ROM small enough.
Um sometimes when I'm using my phone. It freezes completely. Like there's no coming out of it. Buttons don't work and touching the screen is hopeless. The only way to get out of it is pulling the battery but when i do that the phone is done. Like i boot up and it says something about having to wipe and partition again or the phone will be unstable. The only option is the click I'm feeling lucky but then i get a bunch of so and so has stopped working and that's it. The only way is to go to a back up or reflash. Can anyone help with avoiding this problem? Or how to fix?
So new problem.
I have 98 apps total. I am using the fixed INT2EXT+ and now I get a "low storage" notification in the shade. Didn't get that until today and it's been 2 weeks now.
Got no idea what's up...
The dealio: 32 gb SD card, partitioned correctly, 20% of usable space at ext3. According to TiBU, 1.32 GB w/5.4+ gb free. Root Explorer says the Data folder is at 810 megs used out of 4.62 gb.
I just successfully updated, here's how.
From recovery wipe system, boot, and cache.
Flash cronmod's dalvik cache wipe zip for use with int2ext scripts.
Flash newer pac rom
Flash gapps
Flash int2ext
Boot to rom
Eat a sandwich
Drink some coffee
It might be booted now.... Nope it's updating app 78 of 155
Watch some tv
Ok cool now we're back
Lol
Edit virgin fix has old build.prop. Anything new I'm missing?
ajr81
