[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
Re: [ROM] CM7.2 Port for Optimus S by thekraven 2/7/2012 zvd only
Or just start tweaking on your own in attempt to fix things ;) I would be doing that, but I'm cramming for an exam right now..
I am. I have the keypad fixed, but, with no market, its not easy to get apps
Make sure permissions are correct when you copy the Generic.kl, should be
X X O
X O O
X O O
Then reboot
The market issues are from lack of system space , try trimming some ringtones and deleting the bootanimation.zip in /system / media. Or modify the Rom zip and flash. I'll update it with home key fix in a few. Or patch.
For market installs, try
Wiping system and cache , reinstall the Rom and try gannon's gapps.
Delete YouTube from the gannon's gapps. Then flash gannon's gapps with signature off.
X X O
X O O
X O O
Then reboot
Ill give it a shot. See if i can avoid bricking it haha. thanks kraven. the build seems good though.
Did MMS get fixed? havent tried it yet.
So is the YouTube app broken or video playback in general?
>:/ I have to wait for YouTube now
haha its gonna be awhile. theres a BIG videoeditor.apk file that got removed in order to even make CM9 FIT on the Optimus. I think those files contained the stagefright and openGL needed to watch video and stream audio. So that has to be replaced, but other things need to be trimmed in order to get it to fit.
Lupohirp has gotten YouTube to work on the P500, but it broke browser.
The good news is, someone over at XDA is rewriting the entire kernel and drivers to make the camera work.
So hopefully, it will all be committed and our awesome devs here (kraven, drew, other) can port it to our little phone.
Patience, my friend.
Ji
Thanks, installing MIUI on my touchpad should keep me occupied ;)
im running the kravens original version right now. i guess we need to wait for him to wake up before we can ask questions haha.
Yes, the version he sent is working fine for me. Only issue is space. Else, i can download apps without any problem.
After installing last night and messing around with. Ics today I cannot get data to engage no matter what I do airplane mode as well as turning data off then on didn't work. Just getting the word out there. So exciting to play with ics though
Do I flash the mic+fix+for+cm7apha1.zip from recovery?
can i flash it now, even though i flashed the rom a few hours ago?
FYI,I made a new CM9 thread now.
Yeah you can flash the mic fix in recovery.
To gain maximum system room back, I'd wipe cache, system, flash alpha1 rom, flash the mix fix, flash gannon's gapps.
ZVD is just the baseband. You have to use ZVD for CM7, which is Gingerbread.
Wait...isn't ZVD Froyo? I did have a ZVD baseband when I began, and I understand from this post that it's normal for the baseband to be stated as "unknown" after flashing CM7, and the baseband is still really ZVD. But the Android version is now 2.3.7--isn't that Gingerbread? Or does it only look that way because this ROM is based on the GB open source? Definitely I'm now noticing some GB features and behaviors.
CM7 is gingerbread and ZVD WAS for Froyo, not anymore. If you browse through the threads, there is a CM9 ROM as well made to work with ZVD baseband. Baseband unknown is a known thing and not at all an issue.
Basically, our devs made VD radio to work with Gingerbread-cm7 as well as iScream Sandwich-cm9 (like they call it).
Reactions: CardcaptorRLH85
ZVD refers to the radio libs that are used to give the phone cell service. the zvd update followed in the same vein as the zv9 and zvc updates (bug fixes to froyo.) The zvh update changed the radio and happened to include the 2.3 update as well. 2.3.7 is indeed gingerbread.
EDIT: Dang it, invincible beat me to it.
are cm7 updates pretty much done and now future updates are based on cm9?
or are we still expecting more cm7 updates?
If any major bug pops up here or a string of cm7 updates happens, then i can build it in a few minutes now. I build for the Photon too, so I keep busy in my free time.
I'm hoping zvh gets fixed by drew.
I didn't know you build for the photon also. Thats awesome. Just got my wife that phone but trying my best to keep my hands off it, lmao. She is perfectly content with the stock setup and I'm going to TRY to respect that this time around. Ha!
Real nice phone though. All I did was changed her launcher because the stock one is too laggy. She didn't even want to do that but I guess I had to for my own piece of mind, lol.
OK, I've given up on getting data2ext to work on the 2/7 build, now I'm running into a different problem.
I can't get any of my settings to stay set on the 2/7 build. I change the ringtone, and it changes back on reboot. Same with everything else, they revert back on reboot.
On a fresh install, I will:
~wipe data/factory reset
~format boot
~format system
~format data
~format cache
~wipe Dalvik Cache
~flash Debug-FormatSYSTEM.zip
~flash 2.7.2012-barebones-cm72-IHO-Kraven-signed.zip
~flash 2.7.CM7.offline.charge.booting.bootimg2.zip
~flash gapps-gb-20120116-237-signed.zip
~reboot and sign in to my google account
~stop sync of apps and download Titanium Backup and license, then restore my apps that way (no data)
Phone will work properly for about a day before it acts up. I will reboot the phone multiple time in the first hour (4-6), then a couple more times through out the day.
When it started acting up, none of the settings would stick beyond me closing the menu window. I tried rebooting into recovery and fixing permissions. That allows me to change the settings, but they don't stick past a reboot.
Just restored my backup of cm7. After messing with cm9 all weekend I appreciate this ROM and it's greatness EVEN MORE! Just had to get that out:-[
Reactions: Va1ha11a
Back on the optimus till my contract renews in may. So I"m going with this cm7.2. What I would like to know, is the Bravia Engine functional in this build? All the framework is there? It's a night an day difference on the evo3d I had, an my gf's evo4g, it's very night an day. Imaging quality is just loads better.
I flash bravia on all updates, even 2 -7, no harm, not sure it is needed or helps.
Using Tapatalk on a Kindle Fire w CM7 ROM
Edie Raleigh
