[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
Re: [ROM][WIP] CM7 Port for Optimus S by thekraven 10-23-2011
Hey again.
I finally managed to get this to work and I FREAKIN' LOVE IT!
A few questions: can I get the HTC Clock that comes with Sense anywhere? I LOVE that thing. Also, how do I get my voicemail? It doesn't come with a voicemail pre-installed. Is there a market app for it or do I need to flash some package specific to Sprint to get my voicemail?
Thanks in advance for all of the help you guys have provided. I am so thankful!
You can get Fancy Widgets Pro.... It has the unlock animations.
I disabled wallpaper hack, tried Miui theme like usual. No luck.
What happens after you flash the centerclock ones? Does the clock stay in the same spot on the right?. Or does the status bar disappear? IT has transparency too, so no need to flash the transparency file.
Choose the theme in Theme chooser?
Are you using ADW launcher as your main launcher?
According to Zdune, the one who made the patch, sometimes you have to apply the patch, reboot, apply undo patch, reboot, apply patch. For me, it always worked on the first time.
When I'm downloading a file from dropbox on 3G, why does my GPS sign show up on the status bar and its alternating with download symbol. Usually a file download is on the left side and download from dropbox also on the left side withs own symbol. Now i see both dropbox download on left and gps/file download on the right!! Is this normal??
Everything seems to force close for me.
Market, browser(stock), dolphin, music, cm settings, etc.
Thought I saw a file to flash to fix it.
Don't see it now.
Edit: ok, I see it's just the debug format system.zip.
Is this a different one? I flashed one I have one installation and was getting the fc's I talked about...
Just flashed 10-23 ROM. Time shows 9.30pm and I'm in california :(
EDIT: reeboted, now ok :D
When I flash the rom, i flash the build props to switch it to OV. Then i flash bobz gapps. Next I flash the center clock with more transparency, and it stays to the right with no transparency.
If you are going to do a full wipe there is another one that wipes the boot, data, cache, and system. Its faster than doing all four separate wipes. http://files.persona.cc/zefie/files/cell/LGLS670/roms/custom/archive/Debug/Debug-FormatALL.zip
And the standard one only formats the system files. http://files.persona.cc/zefie/files/cell/LGLS670/roms/custom/archive/Debug/Debug-FormatSYSTEM.zip
Then flash the rom and google apps afterwards.
Can you use this with edify scripting?
Yeah that could be what's messing things up. You might try flashing MRG's latest Centerclock patch and see if it center's the clock.
What else get's flashed when you do the conversion? You might flash the patch before the build prop changes.
If you send me your current framework-res.apk and SystemUI.apk files, I could make one for you.
1-mount system
2-wipe cache, dalvik, and data
3-Debug format system
4-Flash rom, google apps, then sprint to ov.
5-flash center clock then reboot
Maybe I'll start over again?
Don't see why i'm getting all the fc's
Are we not supposed to be using the cm7 overclocking settings?
I once had this problem. Non stop force closing, but everything said airplane mode and screenshot....
Mine kept saying media. Stock browser, dolphin hd, and numerous others would close on opening...
Ok
Fresh install and no force closes!
Must have installed some old system apps in titanium...
Did have an issue where settings wouldn't allow me to select always vibrate.
And wouldn't save options for sound widget in notification bar.
Reboot seems to have fixed, for now...
Didn't see this one. I'll try it now. Thanks!
I tries this also but when trying to move apk's from sd card to system app in file manager can not install in r/w will not alow has to be in r/o } problem is mms installed ok but the voice mail has a problem no voice mail notifaction and no messages when call no greeting what could the problem be running kraven 10/23 barebones
I'm currently running the 9/27 build with BobZhome 3.11 kernel as well as Adobe Flash 10.3 from here:
http://forums.androidcentral.com/lg...s/128833-adobe-flash-10-3-tested-working.html
Youtube works through the stock browser - I do NOT have the youtube app installed on my phone.
Build has been working quite solid and does everything I want
I also have the sprint visual voicemail working as well on the 9/27 build.
Any point in upgrading to 10/23?
Reactions: CardcaptorRLH85
Bry
