[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
Re: [ROM] CM7.1 Port for Optimus S by thekraven 11-12-2011
Flashed needy build. Everything seems great!
Except,I can't get status bar to show am/pm at all...
You are right. I never noticed that before. Has it worked before in prior builds?
Random but is there a setting to change in order to get transparent status/notification bar? I have been looking everywhere for it!
Sent from my LG-LS670 using Tapatalk
It worked in the 10-23 build. I think that is the right date?
Just checked. I'm on 11-12 build.
Wonder why its not working for me?
Let me reboot and see if that helps...
Any reason this ROM would affect wifi signal pickup? Seem to not get a very strong signal now...
Edit:
Reboot didn't help clock am/pm display. Won't switch from default (none)
Could it be working for you because of kernel? Which one are you using? I'm using the one it comes with...
Yeah doesn't work on 11/12, but 11/7 it worked .
Darn, got it pinned down enough to re-incorporate next build?
It will be fixed. I see about 3 lines of code that were missing.
Fixed. Push this via adb to /system/app folder http://www.mediafire.com/?dvquykk3frqh8p6
Or use File Expert (root explorer) and delete CMParts.apk , then copy/paste the above and reboot.
Or flash this, it has the fixed CMParts.apk inside. edit try Version2 http://www.mediafire.com/?cndc2cza480rr6w
Reactions: CardcaptorRLH85
im getting stuck at the "Processing download request" page on mediafire when trying to download the full rom...and tips?
Mediafire is being screwy with me too, since they did the update. I found that I can't use it on the phone browser anymore, only on the PC. Maybe try Dolphin HD browser
If I flash the latest. Build over the previous build will I lose my data?
Sorry i'm late to respond. You can flash just the 11.12 framework update and be fine without losing data. Edit: try version2 http://www.mediafire.com/?cndc2cza480rr6w
If you decide to flash the full 11/12 zip, at least do a cache wipe.
Flashed the framework and my am/pm is back!
Thanks speed demon!
Lol...
Just noticed the GPS works good. But, when I hit the notification widget to turn it off, it doesn't seem to turn off. The widget does, but the icon doesn't.
Any idea why my status bar looks like this if I open the dropdown menu? The left half changes to a darker color...
attachment.php
I think that toggle only switches the checkmark in options/location. So next time you use an app that requires GPS, you will get that prompt to turn it back on. You may have to manually stop the program that is keeping it on. It won't kill a rogue application that is using it. I've seen Facebook and GoChat do that.
No, it will just overwrite the SystemUI.apk. I usually just flash over and over without the undo.
719techhospital
