[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
Re: [ROM] CM7.1 Port for Optimus S by thekraven 11-20-2011
I had to manually insert flash_image and so on. But we got it.. Finally! lol
And the weird thing is.. The Market wasn't installed..
did you ever figure this out? you have to flash gapps on kraven's rom as spelled out in the instructions.
Really.. Get a bot rude at the end. Every rom i've downloaded, I've never had to manually install my Gapps..... "spelled out". Mhmk gotcha, "written out"
I'm sorry if you think I was rude, but with every mod, RTFM. lots of people brick their devices, or require help because they can't read the first post.
step 3 under download:
3. Google Apps.. required. Choose and download onto your SDcard. . .
step 8 under installation:
8. Now flash the Google apps zip you downloaded via "install zip from sdcard" again.
"spelled out" is a phrase that means the devs take great care in writting every detail you need, possibly more.
Phrasal Verbs:
spell out
1. To make explicit and clear: asked him to spell out his objectives.
Reactions: rukin1
I got that lol.thanks
What's up with this?
Got a weird bug when I lose my data signal, I get "international data roaming" in the middle of Texas (more specifically west of Fort Worth). I can't data roam unless "international data roaming" is enabled, and luckily Sprint doesn't charge extra for data roaming.
Not sure if this was mentioned but I really like thekraven port however it will not allow me to use data while roaming. I keep getting this international roam indicator but I'm in Pennsylvania :) lol I couldn't find a way to force data. What gives?
Enable both "International Data Roaming" and "National Data Roaming"
Settings --> Wireless & Networks --> Mobile Network settings
Also, can't select "CDMA Network Preferences" regardless of the "System Select" setting (Automatic/Affiliate/Home).
I'm having GPS issues and your GPS fixes are not working! Is there something I missed? I followed all the instructions and I'm still having issues. Any help would be appreciated. Thank you!
What sort of issues?
This might be related or not, not sure. Seesmic (A Twitter/Facebook, ect client) will get location errors when adding your location to a tweet, but it will still add your location
Did you just flash this rom? Did you do a full wipe including the debugFormat-SYSTEM.zip? I am on the 11-20 version and am having zero issues and didnt flash any gps fixes.
I've been with the kraven since day one! This is my only issue ever. I didn't use the debug zip but maybe I should lol.
now i have problem. My buttons below my screen are mixed up.my home button became my menu and my menu became my home lol
What's your GPS behavior? Likes what's going on?
If these fixes don't help, we can try something else. But requires going back to a sprint VD rom.
Here are the latest AGPS fixes from Crypted. AGPS Patch LG Optimus One 3.1 & 2.2 | GET BACK TO RAPID GPS LOCK & MORE SATS - xda-developers
Newest 3.1 AGPS fixes http://www.mediafire.com/download.php?dycqj1btu7nbeyu
Version B (adjusted intermediate accuracy) http://www.mediafire.com/download.php?ndp16l9d1zl3hf0
Version C (more gps servers) http://www.mediafire.com/download.php?ld99yt81xwn8wdn
EDIT. Fixed the scripts for flashing..they should work now.
Patch A is his latest patch from XDA. agps.patch.lg.build.v3.1.zip
Patch B is adjusts accuracy in intermediate mode. agps.patch.lg.build.v3.1b.zip
Patch C has more gps NTP servers. http://http://www.mediafire.com/?g4r34630r2c8lwc
My GPS will lock on fine,then I will search for a connection. It will go in and out of connection quite a bit. Idk if its because I was using it in the city but its not functioning properly. I'm on VD, and ive been using your rom since August.
taisiatetiana
