[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
Re: [ROM] CM7.1 Port for Optimus S by thekraven 11-20-2011
Are you using Xionia recovery? It should work with that one.
Yeah, sometimes the latest is not the best to use. Xionia works and does have a boot loop fixer is that ever happens. It's what workw with pretty much all the Optimus S ROMs.
But here is an Edify system format version to try. See the attached file.
Yeah, sometimes the latest is not the best to use. Xionia works and does have a boot loop fixer is that ever happens. It's what work with pretty much all the Optimus S ROMs.
So you want me to flash this?.. after I flash your ROM?
No, you kinda jumped in the middle me helping someone.
Yours was an improper ZVD flash. You need to flash the ZVD update zip twice for the radio to work. The first time you flash the update, it loads the stock recovery needed to flash a radio. THat's the only way to do it. The 2nd time you flash the update.zip, it actually updates the radio. Then you can root, install xionia recovery, and install ZVD Roms.
I literally just figured that out lol. Thanks sooo much man!
I installed the mod last nite...Everything seems to be working great except...
1. I cant make a call from my contact list. When I make a call, Its ends the call immediately and says "Call Has Been Lost." If I dial a number and make a call it works fine...
2. I'm not receiving any Facebook alerts on my phone even though everything is set to notify me about new messages, comments, etc.
3. I sometimes get a message saying "The application Google Services Framework (process.gaaps) has stopped unexpectedly. Please Try again.
Im wondering if number 3 that has to do with my issues...does anyone have any suggestions on what to do to fix these issues? I love this rom and want to continue to use it..Thank you.
That first problem is created by the fact that your contacts probably start with '+1'. Remove the '+' sign and they'll work just fine.
I had to manually insert flash_image and so on. But we got it.. Finally! lol
And the weird thing is.. The Market wasn't installed..
Man you guys are F'n Amazing!!!! I reflashed the rom even with out Xionia and it took care of the force closures....The other guy said to take the 1 out from in front of the number that I was trying to dial and it worked....I'm broke as a joke now but I will dontate $5 or so to you guys when I get paid next week. You dont know how much I appreciate everyones help!!!
I'm wondering, will this have the ZVH baseband in it eventually?
The kraven why does your status say member? It should say android super dev!
zvh it does. But this guys good. He can do it
But now im haven a problem. Notification keeps popping up to capl my voicemail when i dont have any. I clear my notifications and then it goes away then it comes back nd my phone goes off every 10 minutes if i do not clear my notifications.
Google voice has no issues if installed correctly.
Welp. Now its ben gone for quite a minute now lol. Hopefully its donee
So, the newest update for Netflix still doesn't work...someone in the past said something about a custom kernel?
how would I flash a kernel?
And which one would do the job?
i found a working modded apk over at xdadevelopers:)
Mario Zelda
