[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
Re: [ROM] CM7.2 Port for Optimus S by thekraven 12-12-2011
I have a rom folder where i keep gapps.zip, DebugFormat-SYSTEM.zip, and my edited thunder keypad file.
Makes flashing new roms super easy...
Also, don't forget to back up the titanium folder!
12-12-2011 Barebones:
Screen orientation rotations sometimes does not respond. Google Sky Maps is stuck to nadir once in a while. Something probably wrong with accelerometer readings: it looks like one axis is stuck on 0.
Issues resolved with restart. Saw this behavior in previous versions too, not sure which: 11-20, 12-6 and so on.
Check to see if all rotations are checked in cm settings / display. Also try unchecking all the boxes,and recheck them,then reboot.
Yeah no density change, only the Roboto font from ICS. I'll make the old font available too.
The MMS should be fixed in the 12.12 builds, but I'll keep looking at it. It's the same setup from the 11/20 builds. The apns-conf.xml match.
Try this is you load the 12/8 MMS fix. Goto go to Settings/Wireless&network/ mobile network -> Access Point Names APN, menu key, reset to default, system will load the APNs from apns-conf.xml
Or if you want to fix it manually there.
On the APN screen, click the menu button,
You may see three settings. USCC, CDMA 1 and CDMA 2 (or Sprint1 and Sprint2)
Remove them all.
Choose New APN, make sure it's all lowercase
Code:
Name = Sprint
APN=1
Proxy=
Port=
Username=
Password=
Server=
MMSC=http://mms.sprintpcs.com
MMS proxy=
MMS port=
MCC=310
MNC=120
Authentication type=
APN Type=mms
APN Protocol=IPv4
What's the MMS behavior? Stuck sending or not receiving?
What carrier is it from? at&t are known problems
I'll make a few more MMS apns-conf.xml you can flash. I see on newer Sprint phones it's a little different now.
I will try this and get back to you I just got this phone 2 weeks ago... and could you pleaaassee make the deadzone for closing the notifications bar longer it's frustrating when I'm in a hurry and struggle to close... this would be amazing thanks
@thkraven: I fixed the notification ticker text overlaying the centered status bar clock in a commit I made last nite for changing the status bar background. I added the center clock to the animations so it will go up and away when notification ticker text appears, and come back just like the rest of the icons. If you don't want to pull in the full commit to the status bar background, look at the changes I made to the ticker java files. ;)
OK thanks Jerry. I like all the new additions. Great work.
All rotations unchecked, then checked, restart. Everything works fine. Then I open Google Sky Maps, everything works fine.
Then I go to home screen, and rotations don't work any more nor does Google Sky Map -- it just sticks to the nadir with rotation from the compass. Accelerometers are dead. Restart, and everything works fine again.
Kraven?
any ideas on why i cannot shut my phone off to charge?
Everytime i try it boots
Oh yeah...i forgot to ask why there is no option to use speech while using keyboard.
there is no mic key
there is no mic key
Cm7 bug causes the phone to boot when plugged in. No fix in sight. I just silence my phone if I don't want calls at night.
And you have to download voice search from the market to get the voice to text input.
tried and my phone went into a soft brick..
I waited 10 minutes then just started pressing random buttons out of frustration and it booted up without the fix... of course...
Edit... don't even have any apn options in settings.... I will try flashing 12-12 build tonight... besides 12-12 is my birthday ;) wish me luck
not sure if this is ROM related, prob not.. since installing 12/12 build, when DL from market, i get 'Package File Invalaid' Error. i'v searched this forum and XDA, i guess i'm not the first to get the error. solutoins i've seen are trying different version market, and clearing both cache and dalvik in recovery...both didn't work.. i also noticed in titanium backup, 'interate update into ROM' function is no longer doing anything despite saying intergration complete, it still says '(update)' next to app....any ideas?
Update: sorry discovered not ROM related.. /cashe issue.. oddly enough not dalvik issue.. will start approp thread
I just upgrade to the 12-12 build today and I noticed that the dialer is different from the one I had in the early November build I was using, I was wondering his I can get the old dialer back. I did a titanium backup before I upgraded and was hoping I could just restore it, but I candidates figure out what object is the dialer, any suggestions?
Sent from my CM7ed LS-670
The Rom is fantastic. Good battery life. Love the new features. Great work.
I am however having issues with video, I get a white screen, but I am able to hear the audio. I do not know if it is the rom or the fact I am running Ginger kernel.
thank you!
its the Contacts.apk that has the ICS theming. Just restore that. I was testing it at that time when it first came out. It conflicted with other themes, so i had to remove it. That dialer is available in a few ICS theme chooser apps.
That's a known issue with Ginger Kernel. Make sure CM screen off/on animations are checked off using that kernel. Other than that, it really works well.
thank you!
Ginger kernel will run but its recommended to use the IHO kernel that came with the build. The screen issue is because of ginger kernel.
Sent from my PG86100 using Tapatalk
why is it when i install widgets they do not show up i the widgets "folder" when i tap my screen then select "add widget" ?
silly question ,,i know but i'm trying to find a good weather and calandar widget
Minor UPDATE for 12/12 builds. This should fix some permissions that were missing.
Just flash in recovery.
12.12.update1.zip
If you are using another kernel other than the BobZhome 3.4 kernel, you will need to flash that after this again. Thanks.
byronsss
