[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
Re: [ROM] CM7.2 Port for Optimus S by thekraven 12-22-2011 zvd on
Is this compatible with the UOT kitchen?
Yeah, upload the framework-res.apk and SystemUI.apk . Keep the edify scripts default. And choose MDPI in a few spots.
You may have to check off some settings in the status bar tweaks if you do color changes.
Other route would be to upload one of the themechooser packs from the rom. Like Cyanobread.apk... something like that. And mod onto that. But some things might not transfer over, otherwise do the method up above.
Reactions: aaronrw
Sweet! Thanks for the heads up. And the great build of course.:cool:
Really glad you keep this thread going . And the mods coming ....
When I try to sign into my gmail account it says sever unavailable.
Is there anyway to fix this plus there is no Maket app
Remember to flash the Google apps (gapps) too.
kraven i got an idea for the next update.
you know how the iphone has that double click home button shows the song and options and stuff?
that except coller cuz its on android.
andcan you make it so that the homecreen (locked) changes backgrounds dependi g on the coverart of the googfle music song your playing?
my sisters phone has mvd in her baseband, do I need to do anything fancy before I install this?
Well you need to root + custom recov but I'm assuming You 've already done that.
You need read the instructions CAREFULLY and flash the Google Apps (Gapps) ZIP.
how to get the center clock on the latest build? I saw the 11/20 clock zip, but didn't know if that was still relevant
Its already centered. If I'm right, you shouldn't the clock at all when you flash the rom.
Thats because, the color is is the same as status bar. Go to status bar tweaks and change clock color to white or other color you want and you'll see the clock in the center. If you see it to the side, in the same settings, click select on center clock. Hope that helps.
Reactions: Va1ha11a
Settings, Cyanogen Mod settings, Interface, Status Bar tweeks, Show clock / Center clock / Clock color (it is probably on but black)
Reactions: Va1ha11a
next question: Battery Percentage?
Okay, so i have read through the forum but still have not found a clear answer to a question that has been bugging me. Currently i have reborn with ZVD. I want to upgrade to gingerbread so... What is the difference between ZVD gingerbread and ZVH gingerbread?
heritagevine20
