[ROM][CM9][ICS][4.0.4] Cyanogenmod 9, Android ICS 4.0.4
what is wrong with youtube? it seems to work for me with 5/29 p500 release and wifi working kernel.
We cant use HQ in youtube because we need the ARMv6 OpenMax Integration Layer Libs because its used for HQ recording and playback. Go to hephappys thread and you can sign the petition for qualcomm to release them
Sent from my LG-P500 using Tapatalk 2
Lol i fogot to post abou that lol
Sent from my LG-P505 using Android Central Forums
Hi i've just started with android and i have a phoenix, installed clockwork mod (my ph is rooted), buet when i try HOME +VOL+POWER my phone goes to fast boot, i have to take out the battery and turn it back on, and ot boots normally, is something wrong???
Yeah. Recovery is volume up button, fastboot is volume down button , and for whatever future reference, emergency mode is rather then pressing the home button, press the back button+vol up, but only use that for last resort.
Reactions: car350
wow thanks a lot!!!! by the way can you tell me which rom and kernel did you use? is stable for everyday use?
Well CM9 and AOKP are both stable but i prefer to use AOKP because of the extended customizability. Right now I'm using ICS_Dynamite, which are modified versions of AOKP and CM9, for performance and gaming. You can find the original CM9 amd AOKP at xda in the original development section of the P500 and the modified versions in the general development section. As for the kernel, just go to the kernel thread in this forum and you should find it. Hope i helped.
Reactions: car350
Do you get the boot bug when you shut completely off oathkeeper the one where you have to boot into recovery then click reboot
Because that is sooooo annoying it has to be something in the kernel or has arjen released a newer kernel besides v2 with wifi fix
installed ics cm-9.0.0-p500-UNOFFICIAL_2012-05-29.zip, and the black screen bug doenst show up... looks pretty nice and smooth!!! thanks al lot!!!!
I agree, Oathkeeper, do you know if arjen is working on anything, because he hasn't posted anything in a while
can i use a 2.3 rom with this kernel?? i have the black screen bug and is very annoying...is there any way to get rid of it??
Hey there, i hope this aint offtopic,
I have the p505 like everyone else here, the ics kernel is amazing. finally got to taste ics on my phone..
however, the darn FM RADIO is screwed. not even there.
i tried installing Spirit FM, that too fails to even open crashes on launch.
now im not sure if this is a kernel bug for p505 users, an actual rom problem, or just my phone being annoying..
ive done the wiping thing no help.
i want my radio back ugh LOL anyone who can point me to a solution I will send a virtual hug lol.
Hey, men I just installed the ROM on my P505, everything is really good, the only problem I had is that I can't play videos.
Thanks to -arjen- for all your work man you rule
dumpsterrentals89
