[ROM][CM9][ICS][4.0.4] Cyanogenmod 9, Android ICS 4.0.4
Hi!
I just installed this on my Thrive, but for some reason it's not connecting to the AT&T networks.
Can you help me?
Thanks!
Sorry for double posting use Mxplayer and the armv6 codec for videos
Sent from my LG-P505 ICS using Android Central Forums
Look back a couple of pages before as to which oddbaseband fix you need to use for the Thrive.
Hi!
Can you help me?
Thanks!
Reactions: Rashed1997
I've gone through every single one of the 16 pages and yet I still cant find the old baseband fix for the Thrive. I would be VERY grateful if anyone could link it for me. Sort of need my phone tomorrow and it's pretty useless as a phone at the moment...
Thanks!
Rashed
Also, Arjen, I am willing to help you with anything you need. Kernel logs, debuginign, anything to repay you for your amazing efforts. I gave up a long time ago finding anyone willing to make ROMs for the Thive and settled with ROMs for the P500 and adding the P505 kernel. But now, you have refreshed my hopes for an amazing ICS ROM for our simple little phones :D
I will try to donate something, but I'm not sure I can as I'm a bit short on cash :(
Thanks a trillion Arjen!
Rashed
Should I flash it before or after the kernel?Nevermind, found it: After
Sorry if I'm being pretty stupid... It's 12:25 AM here...
Do you get the boot bug when you shut completely off oathkeeper the one where you have to boot into recovery then click reboot
Because that is sooooo annoying it has to be something in the kernel or has arjen released a newer kernel besides v2 with wifi fix
Sent from my LG-P505 using Android Central Forums
I get that also, but it's a small price for having ICS :)
I did get it to work but that was not the one i used. Also after you install it download dolphin browser and use it instead of the stock one.
Is the same process as gingerbread??with ginger it worked on stock rom
Is anyone having issues with usb storage. When i connect to my pc it start looking for mtp usb drivers and fails?
dumpsterrentals89
