[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
Just clear playstore app data and cache, don't sign in. Then boot to recovery and clear cache and dalvik. Reboot.
This. Or, remove your account from google play, then re add it.
Error 921. It happens on occasion. make sure you are running the most recent gapps.
about to make the switch to a10F.... anything I should know? I just realized I'm 20 pages behind. Don't have time for that! got to go put in an application....
Well I'll report back with my findings.
Note for those that still can't figure out wifi tethering, If you get the open garden apk (because now it says its not compatible with our phones through play) that one works.
edit: forget it, flawless install again :)
edit again: CAMERA PREVIEW!!!
One the issue of clock drift.
When I press the power button off and then on again the clock goes back to normal.
OK can you guys help when I go to download things from the app store it says error purchising item
I was getting this too on certain applications from the Play Store, I removed my account and re-added it and it all works fine now.
who's the right guy to pester for a working version of flash I downloaded flash 11.?.?.? That works for ics and copied the data files but no dice it the only thing keeping it from being my daily
I just turned it on. That version has always worked for me.
Sent from my LS670 using Tapatalk 2
Thanks! That's one more thing off the list. Now if only the CM9 team could solve the Bluetooth audio and offline charging issues.....:)
Sent from my LS670 using Android Central Forums
Click to view quoted image
from a computer, go to the market, then click settings. Check to make sure that YOUR device is listed there. I had the same problem once that fixed it. Check under My orders and devices, and select yours if its not already...:D
Any idea how to reincorporate voice search to the android keyboard? Ever since I deleted voice search and reinstalled from market I can't get the mic icon back on the keyboard. In settings I've selected "on main keyboard" but it shows a comma where the mic icon used to be. I've even tried reinstalling, wiping cache and dalvick but no dice. As a work around I installed ICS keyboard from market but I prefer the stock keyboard with mic.
have it all installed now for awhile, noticeably faster for some reason, love the bubbles wallpaper, switched to maxthon browser which goes well with the ICS theme. Couldn't stand any others anymore and it does support flash plugins.
Did notice the clock lag right away but as mentioned before, just shut off the screen and turn it back on to fix it. Unless there is a newer way to do it.
I can now use camera360 which works great... the preview fix was installed before booting up so I can't say how choppy it was before but its perfect now.
youtube HQ choppy but more consistent compared to A9.
Max volume on the external speaker has increased... I had to set it down a spot or two for my ringtone. scared the crap out of me first time someone called.
Overall great improvement, will continue to be my daily driver. Thanks :)
I really wish there was a hotfix for multi-tasking. Whenever I hold down the home button, it looks like Sense, and is utter crap. =\
You'll like GummyBeam live wallpaper
That is a good one! (On a related side note... I flashed that zip the minute I read your post...this a10(f?) Is just fast as hell! - boots up fast, seems like its gotten a lot faster over the past few days...)
My favorite thing about the bubbles wallpaper is how it interacts with touches and swiping... if the gummy beam wallpaper had that, I'd be sold!
On another unrelated yet ironically related topic -
Have a random reboot at least once or twice a day. In the ROMs defense, I am O/Cing and have a liberal amount of spray paint on the battery cover - she gets pretty warm. I have to pull the battery on these random reboots or it hangs at the cyanogen mod 9 screen.
A few odds and ends apart from that - a regular open wifi network I frequently use no longer works: it connects and let's me browse for just a second but then ceases to work. Have to toggle wifi only to connect and browse for a second again.
Great job, kraven, this has come a long way and I am always open to testing anything new you have in the works.
Like to add... haven't had those clock drift issues. Noticed a lag of like 5 min and it updated quickly.
aimalee
