[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
On 10g with the virgin Mobile fix, I'm using nova prime and every time I reboot the home default gets reset and the widget dies, it's just a blank placeholder. Also I have flext9 keyboard and for some reason I have to open settings and open inputs before it shows up as an input after I reboot it switches back to android keyboard. Video streaming apps such as hbogo and directv and Netflix does not work. Other than that it is extremely stable and just plain awesome.
For nova and the keyboard they cant be moved to the sd.
Reactions: benslgdroid
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
note to all regarding apps2sd:
in all versions of android, anything you move to sd will not be available as a default when the phone boots up, because searching the sd card for apps happens after boot. Therefore anything you want as default has to be moved to phone.
This is a drawback, but that is why all the new phones are coming out with more and more internal ROM memory available.
just keep that in mind when you're moving stuff to sd, widgets, keyboards, home screen apps, etc must be installed in the device memory. Also, since this is Clockwork Mod; if you have your default app installation set to external, your apps will be installed there first, regardless, so you need to move them to phone if you want the widgets and defaults set.
It is meant to keep you from loosing functionality on the device in case the sd card is mounted or dies.
well that was my problem, after all the time you think I would know better.
I've been looking for that option in the menus but cannot seem to find it. I'm use to cm7 so I'm still getting use to the new menus.
What do I have to do in order to clear up some system ROM memory? I just checked and my Optimus V has 9.89 MB left! :/ Are there any things in the /system file that I can delete?
Video streaming apps that require Adobe Flash do not work. Don't expect it to. Flash 10.2 (hacked) isn't playing well with Android 4.0. You'll have to sent your requests to Adobe. They decided not to include ARM6 support.
Wrong, I use an Apps2SD mod and I have widgets and defaults set with no problems. Your mixing up the Android built in apps2sd and apps2ext. Apps2ext changes where apps are stored to an ext2/ext3/ext4 partition which is mounted at boot before zygote starts, Meaning everything works. :-)
Edit forgot to mention ext based apps2ext mods don't suffer from the mounting issues
Sent from my LS-LS670 using Android Central Forums
Apps2SD is built in not Apps2ext. Most mods also remove any existing ext scripts to prevent boot loops. If your getting one from an apps2ext mod, let it go for a few minutes (mine needed a restart after sitting for about 3 minutes but worked fine after.) Also open the one you're flashing and ensure that it doesn't flash anything to /system/libs or flashing binaries that already exist in the ROM (e2fsck, tune2fs, fsck, etc.) As this will cause either hangs or boot loops. If all else fails, download mounts2sd 2.2.0 from my thread in this sub forum and use it, it's been proven to work with the settings in the thread. (you can try the latest version but I haven't tested it yet)
Edit: alpha 11 is running great Kraven. A few lags here and there but it's still pretty smooth. Love it.
My bad, I had this an TDM's rom confused. His puts it on ext automatically. I keep switching back an forth an sometimes I forget which rom has what features.
Ok, with regards to the infamous Bluetooth issue. I'm assuming they have tried swapping out different libs?
I've found there are a bunch of roms that have calling working, but not streaming. Is it possible to rework and merge lib files and get both working?
just a thought ...I'm not sure, can't seem to find a program that reads lib files correctly yet.
Dead puppies EVERYWHERE!
relax 11 will be ready when its ready and not before.
On a different note, anyone on 11 experiencing bad battery life??
Sent from my LG-LS670 using Tapatalk
This rom is so cool some of us would would gladly trade a litter of puppys for the sacrifice
And I love puppys....
For Inverted apps are we supposed to flash those .zips in recovery AFTER we install gapps?
Just flashed 10G....its so beautiful....you don't know how much I'm grateful for this, thank you so much. Its devs like you that make android worth it!!!
I've looked at the bluez source we're using and only one thing stood out: a new "bitpool" check in the SBC encode/decode functions.
I'm not sure if that matters. I'll dig into the MSM72xx audio source (eventually).
I'm struggling to get useful logs out of the bluetooth stack. hcidump seems to cut off as soon as I start a voice session, with only useless command updates being returned (CM7.2 & CM9). I know I'm not getting everything out of the bluez stack in logcat, I'm not sure what else I need to be doing (maybe debug isn't on in the kernel for bluez?).
From what I can tell from the logs I have now though, the CM7.2 and CM9 flows are almost identical, apart from some log style changes.
Quick Note: using the BT Mono app (which routes music audio out over the HSP/HSP link) I am getting the same garbled junk, repeatably. I think that means we can rule out the vocoder and focus on the audio routing/bluez code, IMO...
Ya after you flash gapps you boot up then reboot into recovery and u can start flashing the inverted apps though the apps that you install from market u gotta uninstall first if I remember right..
I had was to remove old Vending.apk, and then install to system via recovery. Otherwise it would not install. Everything else removed the white apk first and installed inverted as part of the process.
I flashed the inverted gmail, and it broke most of my apps..."app isn't installed" when trying to open. and now adb install is giving me ridiculous error messages. idk what's going on. guess i'll be restorying to my 10g nand and reflashing 11a
I clean installed 11a two and a half days ago, with 04292012 gapps. I downloaded all inverted zips to SD, booted to recovery and flashed them in order. After I saw that Play did not work, I removed it with TiBu, booted to recovery and flashed it. All good.
Do you have an app2ext app running? I gave up, each try was a train wreck on CAI after a couple days and some test zips from @thekraven. Just a WAG.
mannanqureshi
