[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
ICSreloaded messed everything up for me. It was cool and stuff, but I couldn't get adb or move files to/from my computer via usb. It just wouldn't work. So to fix that I deleted the reloaded apk from /system/apps and replaced the systemUI in there with the original systemUI. After a reboot, it got me back to stock status bar/notifications. Do you have the problem with adb and file movement on ICSreloaded?
Yeah, I noticed that I couldn't mount USB. That really sucks, I just want stock recent apps.
Sent from my VM670 using Xparent ICS Blue Tapatalk 2
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
I did, yes. I ended up just rebooting into recovery to move files. I've found that I prefer to move files that way.... seems to get a higher transfer rate that way too.... but that might just be my imagination
A few a11c notes:
Nothing is broken for me from last version.
Weather in lockscreen is sick. Works well.
Click drift still an issue.
Don't use bt so can't really comment on that.
Will get more thoughts later today. So far so good..
A few a11c notes:
Agreed, nothing seems broken, but I was unable to download the test 13 kernel. How do you start the weather on the lock screen?
never mind, found it lol
Sent from my LS-LS670 using Android Central Forums
A few a11c notes:
My only concern with Bluetooth is tethering, I don't use it for anything else. Can anyone confirm that it's working on alpha11? It works great on alpha10f.
Sent from my VM670 using Tapatalk 2
You get away with bluetooth tethering? I used it for half a day and got a call from Sprint to stop or they were going to cancel my contract. (PDAnet had no issues)
Edit: Just noticed you're a V my bad.
Holy cow. I'm glad 11c is working for other testers. I really screwed the pooch somewhere during the upgrade process and have spent a good, long time this morning trying to get 11c to a useful state (apps all installed correctly and not force-closing, etc.) I'm going back to a nandroid backup of 10g and trying again when I have a little more patience.
i dirty flashed it over 11a, wiped cache and dalvik cache, and it has run MINT ever since.
Weather on the lock screen is AWESOME. Havent installed kernel 13 yet, seems to be the cause of issues so far.
wifi/data is superb, no lag on keyboards
Just want to let you guys know that this ROM has the bluetooth issue found on other roms, where the address is the same for everyone. The fix in other ROMs was found by mrg666
I tried the newest kernel and it made my 3g go in and out as well as laggy running alpha 10g I think
Sent from my LS-LS670 using Tapatalk 2
no problems here, wifi,data fine..no lags at all, overall seems faster to me..... one thing i've noticed is video cam does not work after flashing kernal 13
what the ?? this reply was something I never saw or typed whoa Lloyd, hitting the juice early??
What Bluetooth issue are you referring to that mrg666 fixed?
Uh....what?
I posted the reply about thekraven github.
AC posted TWO replies.
The first one was a quote of someone I do not know about a recovery problem, and the attributed answer, supposedly from me, was like a crack addict werewolf about to get married to a vampire in the blazing sun. :confused:
I edited it to the post you quoted. Still dunno wtf AC did. The little android dude Lloyd must have gotten drunk and was moving the forum control levers around, screwing it up. :D
I had the same problem. Flashing reloadedICS over this rom will give you stock recent apps along with a few other customizations. Just Google reloadedICS.
Thank you very much, that with the SearchToRecentApps is just awesome, makes me love this rom even more.
Also to "The Kraven" im running alpha 10G as a daily driver and have had no problems with anything so far, just thought id let you know.
Running 10g, Only issues i've discovered is the "Clock" application Doesn't work (so no alarm). Time likes to lag a bit, i just checked the time on it says 8:54 (it's 9:01 here). And that the phone speaker is a bit quiet. Other than that, i LOVE this rom, Best i've ever discovered for any android i've used.
Any Fixes for my issues?
11c - wow wow wow!!
Clean install wifi and data are faster. Touch screen more responsive. No keyboard lag w haptic on. Not sure yet clock lag. Speaker phone still quiet, but speaker on music or alerts is LOUD! Nice work on this one, @thekraven.
LG-LS670 w thekraven ICS ROM & Tapatalk
Abrislignhot
