[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
I'm super duper sluggish on 11c. It might be due to the mod2sd script I'm running; my SD card is 8 gigs, but is only a class 2, so it's not real zippy. I may have to drop some cash on a card of comparable size but higher class.
Running 10g, Only issues i've discovered is the "Clock" application Doesn't work (so no alarm). Time likes to lag a bit, i just checked the time on it says 8:54 (it's 9:01 here). And that the phone speaker is a bit quiet. Other than that, i LOVE this rom, Best i've ever discovered for any android i've used.
Any Fixes for my issues?
Alarms in clock widget, place on screen, touch it.
LG-LS670 w thekraven ICS ROM & Tapatalk
contacts aren't syncing, i tried clearing gmail cache and disabling and re-enabling auto sync for google account, didnt work, I just want to sync contacts is all.
Thank you :)
Thats my whole issue with the alarm. The application "Clock" Crashes on load.
EDIT: Cleared Clock data and cache, works just fine now.
i cant add my google account because settings crashes whenever i try to put in the password for my wifi network and there is no data in my area, any known fixes?
make a nandroid, then try wiping /system and /cache and reflash the latest alpha & gapps
Thank you :)
Wiped everything? Clean install?
Reactions: taha1112
for some reason i cant find the option to wipe /system. and could you walk me through what to do exactly. sorry but im a little new to this.
Pkt_Lnt makes a good point. Did you initially start out with a clean install onto thekraven's CM9? if so, which alpha are you on?
it's likely that you did initially do a clean install, as long as you followed thekraven's instructions in the original post.
to wipe /system and /cache, reboot into recovery. on the main menu, there should be a 'wipe cache partition'. if there isn't (i can't recall whether it's there in xionia, but i know that it is in cwmt), just go to 'mounts and storage' and hit "format /system" and "format /cache".
hope that helps. let us know if you have more questions
i only wiped the /data and /cache and im on alpha 10G
try wiping /system and /cache, then flash 10g and gapps. let us know if that works
make a nandroid backup first though
my options for wipe are:
-wipe all data/factory reset
-wipe /data
-wipe /cache
-wipe /sdcard/.android_secure
-wipe /sd-ext
-wipe Dalvik-cache
-wipe battery stats
-wipe rotate settings
-wipe /data
-wipe /cache
-wipe /sd-ext
-wipe Dalvik-cache
-wipe battery stats
which recovery are you using? xionia? I'm on CWMT-TH6, but i was under the impression that xionia and cwmt are pretty similar.
What am I missing here, guys?
like i said im pretty new to this so how do i find out what recovery im using?
Those options are not Xionia CWMA v1.2518.6, that I know.
@mr1224, all the recoveries I know show the name and version onscreen.
the build is RA-OptS-2.2.1-GNM
and i tried to reflash cm9 and gapps and it still happens.
Reactions: prowlingfox
Ah yesssss, the all in one recovery.
You should be able to wipe system under mounts.
I'd install Xionia if I were you, you want to play with the alpha ROMS or whatever, get a quality recovery.
http://forums.androidcentral.com/lg...covery-xionia-clockwork-cwma-v1-2518-6-a.html
I would advise the same. either xionia or cwmt. I like how cwmt has a couple extra features, but xionia is more widely used.
in any case, once you get /system wiped, go ahead and reflash, and that should fix the problem. most likely, anyway.
otherwise you could start from scratch. do a full wipe (wipe /system, /data, /cache) and then flash 10g and gapps.
mannanqureshi
