[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
still a little confused how to wipe /system though. mounts only has mount /system. and when i select it, it changes it to unmount /system. does that wipe /system?
I would advise the same. either xionia or cwmt. I like how cwmt has a couple extra features, but xionia is more widely used.
in any case, once you get /system wiped, go ahead and reflash, and that should fix the problem. most likely, anyway.
otherwise you could start from scratch. do a full wipe (wipe /system, /data, /cache) and then flash 10g and gapps.
and would a full wipe be a factory reset?
Get a real recovery, install Xionia. Do it now.
What you have is a poorly done abomination, sorry to be so blunt.
No, that just changes the mount state. I'm not familiar with the particular recover that you're using, so I can't really say where to wipe /system. but if you switch to either xionia or cwmt, either Pkt_Lnt or I can help you.
Someone posted above that CWMT will not flash CAI, have you done it successfully?
edit - aha, twas you. Only today's version?
Yeah, that was me. Hahaha. I can confirm that CWMT-TH6 will flash correctly, but when i tried it earlier with TH8, no go.
That is why I have stayed with Xionia - I like solid. ;)
another problem. i dont have terminal and i cant download it since i cant use my wifi to get to the market. and would either of you mind going onto aim or something so this can be much faster? thanks again for all the help
nvm, already had it. forgive my noobness. thanks again for all the help
still cant find where to wipe /system on xionia
It should be under Mounts
there will be 4 options to wipe: boot, system, data, cache
kick ass!!!I'm psyched... still filling in some of the patches...did 10f then goo patches..some lagg as I type ..still no wifi. Even with app...ty though fresh off the press
.lol
tried to do it just now by wiping system and then cache and reflashing both. same problem. then tried a full wipe by doing system, data, and then cache and reflashing both. the problem still persists
By both you mean the rom and the 04292012 gapps?
My wifi doesn't appear to be working properly. Or, I should say, the icon doesn't seem to work properly. Even when it says no wifi, I think I may still be using it. The settings say I'm connected.
Doing the "save-the-battery" airplane mode dance fixes it.
edit: CM9 a11c w/test kernel 13
heidigodofwar
