[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
So, should I expect seamless transitions between wifi and 3g?
Sometimes it seems like I'm having to reboot to transition back to 3g...
And my 3G seems painfully slow...
(I'm runnint 16E, and my PRL is 60687...)
Should I transition back to 15F? or some other rev?
Sent from my LG-LS670 using Tapatalk 2
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 6/26 ZVD basesband Alpha16
I tend to experience maybe a 20-30 second lag moving from wireless to 3G, but nothing too rough. EVERY now and again, I'll switch mobile data off, then on again if the transition is taking too long.
Playing around for about an hour now everything seems great so far. :)
Guess I need be patient... I actually backed up, installed reborn so I could make sure my radio profile was updated and current... and then restored ICS... Tomorrow I'll test it more when I'm at work... I know that this afternoon google maps was effectively not usable... I'll have to test data speed again... (this was in an area with decent coverage where I had to revert to using my work phone to look at the traffic map I wanted to see... because it was taking too long to load...)
*sigh*
Speakerphone looks like it should work now, according to the OP, so thanks, kraven!
Did a clean install using 16E, the clock lag seems to be an issue still and the phone is very slow when typing on the keyboard using Swiftkey. Any ideas on how to fix?
I tired the fifth iteration of 16e and still no joy. @thekraven, do you want another logcat, it looks the same to me from the previous ones?
How's the first 16 version? That still should work for all installs.
Getting it now to try again. I have not had any version of 16 bet past the boot animation, still on 15f.
edit
No look, boot animation hang. logcat attached
Is that with no patches.? If none, then it's more in depth the rom
Just the 16 rom and gapps 20120429, after wiping with COT - wipe data/factory reset and system, cache, data and wipe dalvik.
That's also exactly where mine hangs with all versions of 16 with no mods and a complete clean install
Sent from my Frozen Optimus S
Hmmm. Strange...video playback works just fine for me. I haven't had any problems with it at all aside from being unable to stop/pause a video and resume it from that point.
I cannot watch a video that I recorded with the camera.
No player can play the file.
It shows up in the gallery and other media players but it cannot be played.
Is anyone else getting this.
I can play videos which I transferred to the phone but not when I record them.
EDIT: NVM i havent flashed a rom in so long i forgot to wipe data lol (only did cache and dalvik)
Just flashed 16e and it booted and everything
Wipe system data as well...if you're running cwm you might try to flash the debug zip too, you can find that around here somewhere...
Sent from my LG-LS670 using Android Central Forums
I can't flash any 16 ROM but 15f works for me. A few have this problem. I posted a logcat above, does yours look like that?
LG-LS670 w thekraven CM7 & Tapatalk
A lot of folks seem to have that problem; I seem to have lucked out...the solution was mentioned on the first page in getting some video player from Google Play store...
Sent from a Purple LG-LS670 with CM9...the New Wolzard Phone...yes.
anyone else having isues with voicemail showing up in the call log but not playing from there? I have to play them from the Google Voice app directly.
Would a logcat help in this case?
quick question guys, the problem that some times the phone goes into a comma, its idle and then it won't respond and the only way to bring it back is pulling the battery, this issue is the "deep sleep" right?
mrtalha
