[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Test this boot.img. Wifi should be working again but with the adb and usb fixes. Airplane mode still not toggling correctly. Testing out a differernt wireless driver.
43 has the same same dhcpcd config as previous betas
44 has a slightly different dhcpcd config
Does this flash like a regular zip
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 2/20 ZVD basesband Alp
Yeah, just wipe cache and flash in recovery. Make sure wifi is working before you flash it.
I will be flashing soon... I just need to send it over to the phone via ADB.
Copied via ADB.... Hey... I know how to copy and push and delete files using ADB.... anyone know how to rename or move them?
Just curious.
I know "rm /path/to" deletes.
Oops! I just did a full wipe and install with alpha4, gapps, and img 43. Came up with the UMS app and 3g showing. I rebooted before sign in and it went to wifi and logged into my router fine. Logged into Google account, went to market go get TiBu, it shows downloading, but does not. Cannot get a web page in the browser. I can browse the market but not download.
Rebooted, wiped cache, flashed img 44, and same result. I have never gotten the blue wifi status that is supposed to indicate a Google sync connection. Alpha 1 and 2 would let me get market apps via wifi.
I'm going to wipe and reflash alpha4 and gapps without new boot image and see how it does. In the past I can get wifi until i do the steps of airplane mode on/off and data on/off to get data, then loose wifi.
Same problem here. Wiped cache and flashed 44. Market downloads never get past "Downloading" phase. Wiped cache again and flashed 43. Same problem. Downloads outside the market are functional, as tested when apex pushed 0.4 through the browser.
I'll try to get that worked out. Something with the drm Manager.
Straight up a4 and gapps works with wifi, no data attempt. Got my market apps, and restored a couple things with TiBU. Making a nand, then knowing that I have a working wifi before, can try img 43 and 44 unless you say it is unnecessary.
Try only 43 and 44 if you want to try adb, native usb , and wifi. But it broke market downloads, so i'll see what's up.
Ive been using it since i noticed the Alpha 4 was released, everything flashed fine, gapps smallfile worked fine, had no data but refreshed airplane mode and it started up, installed everything, and i must say this is alot more smooth than the cyanogen 7 i had before, everything has worked flawlessly not using default browser, "skyfire", for a flash workaround, after downloading each app it nags me "no more room on this Home screen" but places the icon on the home screen anyway, other than that im super happy and will be keeping up to date on this thread ;)
Thanks. I got the same result, wifi works, but market does not with 43 and 44. Back to straight a4. I use Box under CM7 to transfer files for now. For me, wifi is more important than data, adb, wifi in the early testing.
44 screwed up my wifi. It also has a bug for not rotating the screen automatically.
Try force closing market.
Same thing here...wifi works, market doesn't, and auto-screen rotation doesn't work either.
Also; my clock doesn't seem to update all of the time when the screens off for a while (before the wifi patch). Usually I have to unlock my phone and wait for a few minutes and it fixes it, but luckily my alarm always manages to go off on time :confused::confused:
jeromepare89
