[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 2/20 ZVD basesband Alp
I haven't tried the new boot.img patch yet however, Gallery started working for me today when I went into the Facebook App and hit Post Photo. It showed me the images on my Card in Gallery and let me select it. I opened it from the launcher afterwards and it still works fine.
TheKraven: just keep doing what your doing :D Your ROM rocks!
Attached is a screenshot of Gallery working correctly.
EDIT: Forgot to mention, this is Alpha4
the boot.img patch breaks gallery. also, calculator doesnt work. random. haha
Are you guys providing logcats to the Dev? It really expedites the trouble shooting process.
if he asks for them, we all will. with this being a public alpha, i dont think kraven really needs 500 dmesg or logcats posted about the same problem.
Reactions: PatrickAkridge
I'd rather have 500 logcats with the same problem than 500 duplicate posts with nothing of value to work from other than "it don't work." Lol just saying.
Id rather have a clean, concise thread then 500 posts of 20,000 lines of logcat code. If kraven wants data he doesnt have, he will ask.
A lot of us communicate with him via PM. if you want to post logs, be my guest. Im just saying, it will get messy, fast.
I've always zipped or more recently DB my logcats or a similar method(IRCs seem preferred these days) in order to actually help devs move forward faster. I was just making a suggestion as I've just rooted my sons optimistic s. Hope to see a daily driver beta soon good luck guys.
Sent Via My GSNexus
If you do send logcats, use pastebin.
Here's a new boot.img with market working.
Reactions: tlrsax54
If it still breaks rotation and gallery. You can flash Iscream kernel after the boot.img.
Edit: gallery and rotations worked for me. I had to force close it, then reopen it.
Thanks leaven. Downloading now
Sent from my LG-LS670 running CyanogenMod 7 and Gingerbread
cm9.55.zip broke my wifi. it connects, gets an IP address and authenticates, however, it will not allow data to flow.
any ideas?
wifi worked before i flashed it.
if i dirty flash the rom, will it roll back the update?
any ideas?
Me too. Same result. I do a nand and just restore before the next try to break something. ;)
sent from LS670 w thekraven CM7 using Tapatalk
any ideas?
It should. Try flashing iScream kernal.
A lesson I learned as a rookie last year, NEVER RENAME NANDROID BACKUPS! YOU'LL GET MD5 MIXMATCH!! ;)
I did that, no help. However, it DOES seem that this new boot image is allowing me to connect to mobile data services more consistenly, though I cannot think of how one could affect the other.
Has anyone found a work around to get data to connect on reboot without having to toggle airplane mode?
Try forgetting the network and turn off/on wifi then reconnect. For some reason it takes a reboot before wifi data works.
Cis there some way to get wifihotspot working?
ibukkkkkkkkkkkk
