[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 2/20 ZVD basesband Alp
Try forgetting the network and turn off/on wifi then reconnect. For some reason it takes a reboot before wifi data works.
flashing new boot.img also broke wifi for me, tried doing the above with no success.
You can rename them, I do all of mine. Just don't use spaces.
I rename, and yes, no spaces. Otherwise I forget what they all are - I may have a dozen with all the various test things to try. Use CM9.A4.w.ISK.w.44 or CM7.02.07.12 and they all work for me.
The forget network, toggle wifi, toggle airplane, reboot does not get wifi back for me. I have to restore or flash the A4 ROM and GAPPS.
All is good here with .55 img. Solid Wifi, market, auto rotate home screen. Still not remembering settings.
Wiped just cache, flashed .55 img, flashed Iscream kernel, fixed permissions.
Reactions: Pkt_Lnt
Here's a couple boot.img.
57 fixes multiple dhcpcd settings eth0 and wlan0. Wifi connects faster for me.
58 same but with Cheatman fixes.
service dhcpcd_wlan0 /system/bin/dhcpcd -ABLK wlan0
Reboot usually fixes wifi, at least for me.
And i made the alpha4 boot.img flashable too to got back to it.
Flash IScream kernel afterwards.
OK prize for you. Awesome.
sent from LS670 w thekraven CM9/ICS using Tapatalk
57 fixed my wifi again, hopefully it stays! Thanks!
Gonna make the switch to cm9alpha4 from cm7 inthe am. Anything I should expect? I'm kind of a noob sorry. Kraven you rock!
From what i've found for wifi, dhcpcd and wpa_supplicant will need to be upgraded to newer versions... version 6 or 8. Luckily LG still uses the same bcm4325 wireless chip in their newer phones.
Right now we are on
WPA_SUPPLICANT_VERSION := VER_0_5_X
It's, of course, a Work In Progress, so don't expect everything to be working :)
Kraven, I am running one of your older CM7 builds and really want to try out your CM9 build. I am just wondering if this would be a good daily driver or not. This is my only phone and can't afford to mess it up. I also use the native hotspot on your CM7, does it work on the CM9 builds? THanks man I love your work.
Can anyone answer my questions please? I see tha Kraven is offline.
how long did the first reboot take for you guys? this thing is taking forever for me
Double posting is not necessary. Please be patient, AndroidCentral is NOT a 24/7 Helpdesk.
I would not consider CM9 to be a daily driver for most people. While many things do work, many more do not.
Sorry about the double post and thanks for your responses to my question. How close to beta do you guys feel this Rom is?
so i've tried installing this all both ways listed and i just get stuck at the lg screen? anything?
first rule of cyanogenmod.
ibukkkkkkkkkkkk
