Re: [ROM]COLD AS ICE-CM9 Sprint LS670 10/6 ZVD basesband Alpha17
ALPHA 18 . uploading.
- Added Fastcharge toggle to the notification drop down.
- Test 21 kernel.(says test 20, builder error
) .. - Sprint VVM 9016 fixes.
- Home button to answer calls
- audio routing fixes
- Nav bar buttons and option from KonstaT
- Circle battery mod
- Line battery bar
- still has gmail whitescreen , got the fix, but won't boot maybe next release.
- the fastcharge toggle works independently of the CAI parts switch... will try to fix later. So use either one to toggle it on/off
- needs a new virgin patch
