Re: [ROM]COLD AS ICE-CM9 Sprint LS670 10/6 ZVD basesband Alpha17
It has the built in scripts from quattrimus. It automatically moves dalvik and installed apps to sd-ext, if you have a sd-ext partition already on your sdcard. Otherwise everything stays on internal.
I tried using Link2SD,
But when I partition my SD Card it won't mount. Yet- as a single partition- it mounts fine.
So, is it supported or not?
