[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Im holding out till alpha 5, hoping enough is fixed for my "everyday use" keep up the great work you guys ,. also do you/ thekraven and drew have paypal buttons so i can donate:)
Check out the first post of the cm7 thread for kraven's Paypal.
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 2/20 ZVD basesband Alp
Bottom left of thekraven sig has a donate button, use it, great dev!
Now I just need time to test! Work, ugh. Time coming this weekend, yahoo.
Just reading through Lupo's thread on xda...looks like hes fixed everything but the camera :eek:
Does this mean next sync we should have everything working? Or at least closer? ooooh
It looks like he got data ironed out too.
can u give me a link to that thread?
not if it breaks the speaker on the phone. But it does wonders for the headphones.
Ahh I know lol. If anything. If you could possible incorporate it with this sweet rom. Could you add a setting to turn it on and off. From the Notification are or via toggle? I have the Dr dre headphones lol.. I would LOVE this software with this rom. I listen to music all day while I work. I use this rom as a daily driver. It does wonders and I really don't have problems and i don't mind rebooting my phone to get wifi to work.
What's up thekraven, how are you and I hope all is going well.
I see no reports of latest boot image tests. I tried 62 last night with success. I have more time this afternoon. I wonder others comments on these?
Using Tapatalk on a Kindle Fire w CM7 ROM
Kraven, what do these commands to (from the OP)
Code:
export USE_CCACHE=1
export CCACHE_DIR=~/android/system/ccache
prebuilt/linux-x86/ccache/ccache -M 50G
I'm running my first build, wish me luck ;)
I have a few questions about syncing, should I be asking here or 'Building your own ROM' on OV is more appropriate?
EDIT: Yikes I got this :(
Code:
Fetching projects:   9% (22/238)
error: Exited sync due to fetch errors
Its good if you have low disk space and you can also designate wherever you want the cache to be other than the same drive. It makes rebuilding faster.
You might look at making a swap file too, if your ram runs low
Fetch errors are if github is not syncing, just keep trying or look to see what the 22nd item you are trying to fetch is hanging on. It could be a typo or missing branch.
Reactions: Invincible Madness
Kraven need anybody to test alpha 5 or something PM me :D
Check post 475 for the wait.
Have you tested the bootimages in post 490? What results? Mine are inconsistent, so I am working through them before I post.
Whoo Didn't even see that ;O I'll try 67 soon (:
I suggest this rom to the fullest over all great work my hat is off to you Bro's (if i was wearing a hat)...
I haven't flash it yet but I love thekravens CM7 so I know his CM9 will be bad ass.
Kraven, your inbox is full :p
and there is no sun java plug in for amd64 computers. but doesn't the repo process check for all needed components before initializing, i remember seeing it (like its checking).
It's been awhile since I set up mine.. But lookup how to change the default java to sun java 6. Go ahead and post in the building threads on the V section. If I don't know the answer..
wilderjohn7
