[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 3/14 ZVD basesband Alp
Isn't that kinda advertising that I am hacking my phone and voiding my warrenty? Is there another way?
you know its not against the law "yet"to hack your phone,just tell them that your data or prl wasnt updating and you where trying to do it yourself,i got mines by switching between different phones,the have to give it to you when deactivating or activating phones :):)
Due to the snafu that was zvh update, we have the perfect reason to get that code. Since it is common to lose data apon a reversion from zvh to zvd with THIER rollback update.zip you just call up customer service(due to no service after the downgrade), say you wanted to do a ##786# reset but it keeps asking for a 6 digit code.
More bug reports: In addition to the problem with muting calls, the volume control is very bad. Also, pressing the power button while in call hangs up the call.
I have a feeling that you found the last one out the hard way.:(
However, it is still in alpha phase. Kraven's an awesome dev, things will get fixed.
Va1ha11a: I have no complaints. The ROM is awesome, though I'm coming to realize it may not be my main driver quite yet. I know that it takes a lot of work to port it and I really appreciate Kraven's hard work. ICS is far better than Froyo (I tried Kraven's CM7 but liked Reborn better) and I'm looking forward to seeing a fully stable version. I'm just reporting bugs so we can get there sooner, since I don't have the time to start learning Android development myself right now.
End on power is under setting, accessablity. It is usually off, check that.
Using Tapatalk on a Kindle Fire w CM7 ROM
droidmike:
I'm sorry for my earlier comment. I came off as a jerk, and that was not my intent. My apologies.
Have you had data on other builds?
I just noticed that the sb clock disappears when the screen is locked
I think I briefly had data on A2 by continuing to toggle radio/airplane mode but it was incredibly shaky. since then, no. and i've tried alphas 4 and 5.
Va1ha11a: no worries. I do that every day :)
re: power button ends call. I checked and the setting was off. I toggled it (in case we have it backwards) and tested, and still hangs up. I turned it off again, rebooted and it still hangs up.
Reactions: Va1ha11a
sighhhhdatahatesme
Also.. have you tried toggling data/airplane mode?
Me too, data blacklist. :)
I have only had reliable data with A4 and bootimage 67v8. I have installed every alpha from 1-5. I have saved links to all the data tricks posted in the thread and tried them, the APNs, the toggle airplane and data, the *#*#4636#*#* and toggle preferred network and radio off and on. On A5, i had wifi and data after initial flash, but once I toggled some settings and rebooted, I get great wifi, blue bars and activity indicator, but no, and I mean no, data. I even installed an app from opensignalmaps that has some great indications of signal. I shows me on 2.5g with an -1 asu - always.
I'm surprised. I have to do a little "toggle dance" every time I move away from wifi, and it's not always the best performance, but I can GET data fairly reliably.
The Toggle Dance
  1. With data ON and airplane OFF, toggle wifi OFF
  2. Toggle airplane ON, then OFF
  3. Toggle data OFF, then ON
It sounds like you have a further issue somewhere that probably won't be fixed quite this easily; thought I'd post my reliable process anyway. Maybe a miracle will happen.
The Toggle Dance
I have done those exact steps. The fact that a4-67v8 worked keeps me trying.
sent from LS670 w thekraven CM7 using Tapatalk
Lets try a little experiment. We get everybody to flash the same stuff, and toggle the same things, add than we see what happens
Another boot.img to try. On my test build adb and native usb is working. So please post your results. So you can remove the usbstorage.apk via titanium backup if both are working.
Edit made another one, See if the clock matches up better in v6
V10 has a few more permissions for camera, still no preview. And uses init.thunderc.usb.rc now for adb.
V12 same was v10 just a fresh make.
Every time he posts its like Christmas all over again! ;)
USB mounted and I copied the old a4-67v8 boot image. Check!
Code:
C:\Documents and Settings\tjs>adb devices
* daemon not running. starting it now on port 5037
* daemon started successfully *
List of devices attached
A0000028D1xxxx  device
C:\Documents and Settings\tjs>adb get-state
device
C:\Documents and Settings\tjs>adb get-serialno
A0000028D1xxxx
C:\Documents and Settings\tjs>adb reboot
It rebooted, Check!
ajr81
