ARCHIVED: [ROM][FASTEST iHO]ICSandwich2.3.7 [05|21|12]
Status
Not open for further replies.
Re: [ROM][FASTEST iHO]ICSandwich2.3.7 [05|10|12]
With the reports back of laggy launcher and whatnot I will wait until the next update. v4 isn't too terribly bad. I really hope you can finish this up unknown. You do great work. I know I do get excited a lot about you releasing these updates but I hope you don't feel too rushed at times.
Remember it's your ROM. You release as you deem fit (:
Reactions: braxton355
Swift Android Development
Besides the lag it is almost done :p
Yes there is a lag but I still appreciate the work you put in. I agree with comments from some of the others. 'It is your ROM, release it when you are ready.' Have to be honest though I do look forward to the updates, but then when I have issues not sure if it is my phone or just a minor glitch with the ROM.
Either way I can't say much. If I tried to do any DEV work I would start creating expensive paper weights! :confused:
Keep up the great work, and we will be patiently waiting for your next release!!
Reactions: Badboytoast
What is the best recovery to use for this rom? The IHO recovery?
V5 most def looks sick, going to give it a try soon! :D
hey, thanks for the link to your site. pretty cool info an I plan on trying things out. I opened up some files an looked thru them, but nothing looks familiar. can anyone point me in the right direction as to what everything means? like what calls what, syntax, etc. the language is so different from any coding I've ever done an I've worked with c++, Java, and HTML.
U have to set user agent to desktop for mediafire to load
To download V5 media fire doesn't load
Sent from my VM670 using Tapatalk
It may just be how your trying to download it. I tried it on my PC and its working fine still. I have noticed on some roms that when I opened a link on mediafire it just opened to a blank page no matter what browser I tried.
Use your pc to download then transfer it over via adb if possible
I used those tweaks to but on pics does make a difference nd thx :)
what is the name of the keyboard .apk?
Is it located in the system/app?
Status
off8485
