[ROM][GINGERBREAD] CyanogenMOD 7 Nightly Builds.
So you got your apps back then tho Titanium Backup I assume.
In the cyanogenMod settings there are a bunch of customizing you can do there, Menu button>settings>cyanogenMod settings
Ask tho if you have any questions about
sent via TaPaTaLk
Welcome to the CM7 world.
As for your apps, once you pay for them, you can download them again all you want. I personally recommend you download them all again. That way you have a fresh install of apps with your fresh install of CM7. I ran into an issue where I apparently had an issue with an app that wasn't playing nice with Carbonite Fusion. I would flash a fresh copy of CF, and restore apps from Titanium. Once I did a fresh install of CF and fresh install of apps, all was well. :)
There are too many CM7 options to list - check the OP for a bunch of good stuff. ;)
Speaking of the OP - Congrats Crondable for over 2000 posts in the thread!!!
Soooooo. Two things I noticed. I finally had to clear cache in the mail app last night. Just stopped getting email and would not load large emails to view. Weird, never had to do that before but all is well.
Also, anyone notice that a Voice Mail notification now beeps until you acknowledge it in the notification bar? Or is it just me.
Reactions: crondable
This is like having a new phone! Are there tips and tricks about CM7 i should know about?:)
Welcome to the exciting and time consuming world of flashing ROM's. Wait till you realize what a good nandroid can do for you and you start flashing a ROM a week just for something new to look at. :D
Holy crap, 2000 posts. Crazy. I just made this thread because I was bored, and wanted to contribute. I definitely never expected this thread to blow up the way it did. Thanks to everyone that has taken over this thread. Big ups to Pville, Dark Wizard Montoya, ucluglee, davidinc, etc. I try to pop in and answer questions when I can, but you guys are so damn quick!
So I'll do something only I can do, update the OP with a new incredikernel :D Features some updated drivers, and FAST CHARGE OVER USB! Plug it into the computer, car charger, etc., and still have awesome fast charge.
http://www.incredikernel.com/wp-con...php?id=2.6.38.8-incredikernel-gb-07062011.zip
USB Fast Charge Enabler; http://www.incredikernel.com/wp-con...-monitor/download.php?id=enablefastcharge.zip
Chad has also released a v1 of an app that should take care of the slow SD card speeds with the .37+ kernels; http://www.incredikernel.com/wp-content/plugins/download-monitor/download.php?id=sdspeed.apk
All of this will be available in the OP, but I'm sure someone will ask for a link within 10 posts.
No nagging notification here. You talking about the default voice mail notification or Google Voice?
Default - I've seen others post this elsewhere, but other than flashing the OP ;) there have been no answers.
At first I was WTF?!? then I kinda likes it since I never bothered setting up distinct sounds for various notifications, at least now I know it's a Voice Mail! ;)
I haven't flashed 127 yet so maybe it's self correcting with that.
I can honestly say that's one feature I have never used. Been using Google Voice since beta. :cool:
sent via TaPaTaLk
I haven't. Think I need to reload titanium...This is stupid, but I want my AB and PVZ progress back!
So here is the next question...when I want to flash a theme, or a kernel, so I have reflash everything, including wiping everything and starting from scratch again with google, apps, contacts, etc?
Nope. If your flashing a kernel or a theme or some other kind of mod (I use a mod that replaces ADW with the stock Gingerbread launcher) you can just flash them on top of CM7 without wiping. :cool:
Yeah you can just reinstall TB and get your apps back tho it and not loose your progress . ;)
after opening TB> menu button>batch>Restore missing apps with data> a list pops up showing you the apps.Never reinstall system data tho just the app data
I usually make a back up before I flash a theme just in case I get tired of the theme(you dont really want to install a theme on top of a theme,,there may be traces of the previous theme left behind).
Before I flash a kernel I wipe cache and dalvik cache in CWM, no need to wipe data ,or reinstall gapps as mentioned above by DWM
<perk> What mod is that, might I politely ask? :)
I thought you only flashed stables! ;) LOL
The infection has begun!
Another nightly convert!! <<rings bell>>
anyone use torque successfully with CM7? i think the bluetooth drivers are bad and i cant get it to connect succesfully with my adapter for torque to work.
AnthoBrowq
