[ROM][GINGERBREAD] CyanogenMOD 7 Nightly Builds.
Good, never had any wifi problems till #124.
Edit: nope..Wifi still borked. Repairing permisions. I'm assuming no one else is having this problem or they'd have posted it by now.
Ok, question. It looks like the next nightly is going to have this update: camera: Implement touch-to-focus. This has me interested. Since I'm running 7.1 RC1, to install this nightly should I do a full wipe, or cache/dalvik only?
Cache/dalvic only should do it. I went from the RC back to the nightlies without a full wipe with no problems. :cool:
Reactions: Lee_Bo
Just went from #118 to #125 - No Wi-Fi problems at all.
I do like the new mail icon in the 4 tab lockscreen.
Not sure whats up with my Wifi. The wife's Verizon-branded-Apple-device-that-I-Won't-Name is on our wifi and working 4.0. My laptop is connected, our iMac is connected, just my phone thats acting twitchy. I did get it to connect but that was after a fix permissions, several reboot's and lots of turning my phones wifi off and on. I even deleted the ssid and manually added it back in. Weird.
I love the four tab lockscreen, especially since it pretty muck eliminates the need for me to use Widget Locker. I have a shortcut to the camera set on my lockscreen and it's awesome. :D :cool:
Reactions: Wanda
Thanks for the gouge! Camera app from the lockscreen is going to be wicked handy if you've got kids...don't know why I didn't think of it before!! *hits self in forehead*
Sounds like you have too much Fruit on your network. They are gumming up the works! ;)
I'm guessing you tried clearing cache again.
@DWM - I've been using the 4tab from the get go. I thought about putting the camera on the 4th tab but I use e-mail way more than the camera.
I have the camera on the fourth tab now, but I switch between Gmail, the camera, email and Vignette.
I have been looking all over for how to flash my google apps and account back onto my phone and am not really coming up with I am looking for. I have flashed CM7, and after flashing the ROM I repeated to process for GAPPS, and when the phone boots, I get the Market icon, but it won't start, and I can't set up my google account. Do I need to do something different?
Did you do a full wipe, including cache and dalvik? When I went from 7.0.3 to 7.1, I had to do full wipe, cache and dalvik three times each. The reason I did it that was was because after the first flash to 7.1, a lot of my settings and backgrounds were still there, even though I hadn't re-installed them yet. So you may need to go back and clear them all three times each.
Here's a direct link to the latest GAPPS
http://goo-inside.me/gapps/gapps-gb-20110613-signed.zip
Download to your SD and flash in recovery, since you are having issues you will want to wipe Cache and Dlavik as ucluglee suggested.
If you are still having issues after that, then I would recommend a clean install, wiping data, cache and dalvik, re-flashing a nightly and then GAPPS.
Good luck.
Ok, 126 flashed. Really liking the touch to focus feature on the camera. Haven't found the tabbed lock screens yet, but that may be due to using a pattern to unlock since I also get work email on my phone.
gulbhahar36
