Same here with Nightly 171Flashed.
So far, so good. The first thing I noticed is signal strength went from -79 to -64. Very nice.
Try ZEDGE app fool! Its free and there are many many ringtones, notifications tones, wallpapers. Its not CM7's job to make ringtones lol!! They include it cause they're cool like that.The only problem i have with CM7 is that i dislike the ringtones/notifications very much.But other than that, it's the business!!
Any advice on what I mentioned above??
I've actually been using his governor since Saturday night but it's only made a minimal difference. There's still got to be something draining my battery so quickly.Shamless plug for Chad over at incredikernel.com. I use his 081511 kernel with Smartass governor set at 128/844 and get really great battery life.
In most cases it is an app that drains the battery by constantly accessing data via either wifi or 3G. Nothing magical. Find your bad actor or do a fresh wipe/format and slowly add apps till you find bad actor. That is the easiest way. Or you could spend hours troubleshooting. Good luckI stay on Wifi all the time at home as all the threads on here say that saves battery which it really does. I know how to check what's using it but it never shows an App as the culprit. The majority of the time it's the Display that eats the largest % but I have it on a 15 second timeout and auto brightness so there's no way that's the only thing draining it.
Appreciate the suggestions but I know with the experts on here there has to be a more technical method to figure this out.
