[ROM][GINGERBREAD] CyanogenMOD 7 Nightly Builds.
I tried to find LP plus and I cant on the market for some reason...
Yup you have to dowload launcher pro
AppBrain Android market | LauncherPro
then there is a link in there of how to purchase the pro version since he is in spain I think .(from his name) So he has to do it that way.
I dont know why off hand why you cant use ADW pro after you upgraded to it .What does it do ? or doesnt do ?:confused:
when I go into my apps in the market, it is showing as purchased, so then i click on it, then click install, it says it is DL'd and then it just shows as purchased again, not installed. same as my setCPU but I took that off on purpose. I am dumbfounded. also, it isn't even showing up under my appilications under settings -manage apps.....
Anyone able to listen to YouTube but still turn off their screen without it shutting down YouTube ?
I wish someone would implement that
I was curious about your question so I tested it on my dinc:
I'm on #21 and just picked a random video of youtube once it started I turned off my screen(power button) mine keep playing ,didnt shut off youtube when I turned off screen.
Hmmm odd . First qustion I can think off is :
Is your download from unknown location unchecked ? or debugging unchecked?
Not sure what you mean by that... I just went onto the market and DL'd the ADW launcher Pro, the only one that there is on the market.
yes, I do have allow DL from 3 party checked, if thats what you mean
Yeah thats what i meant :
Menu button>settings>Applications>unknown sources.
I usually have that off except when I have to turn it on but just a preference I guess.
I have noticed once when I had debugging ticked though a app didnt wana download once ;
Menu Button>settings>applications>Development>USB debugging.
Thats why I have those unticked unless needed tho
So, now what? I have emailed the Developers twice, if I cant get this to work I at least want my money back. I am stuck. How much was launcher pro?
I went into my supermanager and cant even find it there... its like i paid for air.
Find ADW.Launcher in your application settings, scroll down and click 'clear defaults'. Press your home button, and it will prompt you to pick ADW or ADW.EX. Pick whichever one and press the use as default option at the bottom.
I don't have the option to clear defaults. I already thought of that... I am stumped... I have no clue what to do.
You have a rooted phone and u still have to buy apps? Am I missing something.... uhmm sideload?
Why did you have to purchase
it's called showing respect to the developer. developers put alot of time and effort into these thing... howd u fell if people were stealing from you
What would happen if ya tried home switcher from the market to use to switch to whatever default launcher you wanted?
sent using TaPaTaLk
ill try it i quess... I even tried going back to a way back nandroid and that didn't help.... what is boggling my mind is that I cant even find it with root explorer...
nEvermind (edited comment) sounds like its another program not just the key like I said at first. But regardless I'd try Home switcher since all else hasnt worked yet.
sent using TaPaTaLk
Did you buy ADW Pro or ADW.EX? Because ADW.EX is that paid version of ADW... I don't know of an ADW Pro...
Tried using a home switcher and it isn't even recognizing anything buy the basic adw that comes with CM7.... and i already though about the KEY thing you mentioned and I cant do anything differently. it is still the same version...
SOOOO.... I just tried to DL and install the free adw (successfully) however, CM7 will NOT let me even use it at all..... I don't think it is an option to even use ADW or ADW EX with CM7.... we have to use the ADW that is already built into CM7 nightlies.... kinda sux
who could I ask that would know that for sure???
I SHOULDA DONE MY HOMEWORK FIRST... IT IS NOT POSSIBLE TO INTEGRATE ADW EX INTO THE CM NIGHTLIES AT ACCORDING TO SOME OTHER (NAMELESS) :) FORUMS.... JUST WASTED MONEY. but it still blows me away that I cant even find it with root explorer
Maybe they will fix it so it will work in furture updates tho . :)
So its not in root explorer >/sdcard/download I assume
That would be freakin awesome if they did make that an option. I mean, I know people that have DL'd launcher and use it with CM.
and litterally I cant find it anywhere on my phone. except right here :)
StevieD49
