[ROM]Gingeritis 3D v1.0 Beta VII [08-08-11]
How has battery life been on this rom?
Tbolt meatclaws-talkatap
My battery has been fine, thought I did find it weird that when I pulled it off of the charger this morning it went immediately to 95%. I would have been concerned, but my battery has lasted pretty much all day long
Is there a way to disable the shutter sound when locking and unlocking the phone I can't seem to find it. Besides that sound I'm really enjoying the rom very smooth.
Believe it's under Settings-Sounds. Scroll down and you should see Screen lock sounds.
Funny I didn't see it there last night when I looked since then I restored my cm7 backup I 'll try later thanks for the reply.
It's funny, turning off that sound was like the first thing I did. No need for it in my opinion! ROM has been running tip top though, it feels a bit snappier over the version VI.
I have assigned ringtones to some contacts, yet they sometime will not play or will get confused and play the wrong ringtone with the contact. Also the touch screen will at time not respond to touch.
wow!! i dont know the differance between VII and VI but battery life is horrible with this one. 2hrs off charge and already lost 32% battery. i even calabrated bat and wiped battery. also noticed to that when off charger for some reason the battery back gets warm.
what i am thinking its the radio, i used the same radio as VI and its using the 4G signal, it DRAINING the battery fast. on wifi last night and it only drained about 30% in over 6hrs. maybe reflash the radio to see what would happen then
While my battery life hasn't been as bad as some others, it's definitely not as good as it was on VI...thinking it's time to go back to VI.
Battery life for me was atrocious on both ROMs for me not sure what the deal is. I still finding VII better than VI in terms of performance.
That is completely normal. The way that these batteries charge is that they fill up to around 100 and the stop charging and then when it drops to a certain limit it will resume charging and it cycles like that. There is no point in charging the battery the entire time and keeping it at 100. I would assume that this is better for the battery and makes it last longer.
Couldn't answer calls. Not sure if there is a fix. Dealbreaker for me, I love this rom.
No issues answering calls here. Maybe an app conflict?
Na its a known issue. I am now running UBER BAMF but it sounds like it's an issue with it too. The screen is the same screen you would normally have when you are on a call but this happens when someone calls you, so there is no way to answer.
I keep wanting to try this ROM out... but then keep reading about the battery life not being as good... now calling issues... I guess I'll just have to wait until the next version. :'(
Thank you that worked perfectly
Now one more noob question do you know how to make the wallpaper scroll?
Just enable the streak live wallpaper. It will scroll as you scroll around the Sense 3.0 Rosie. I assume this is what you are talking about.
Edit: battery life seems great on this for me so far today. Using the official MR2 radio. I haven't tried Chingy's leaked GB alpha. Going to be my daily driver I believe.
Edit2: No call issues for me either so far. Made a bunch of calls and received. Again, using official MR2.
I will update if anything changes but so far, no force closes, no issues at all.
Machetaseo
