[ROM][ICS][Aug 18, 2012] Android Open Kang Project [Stable 4]
Status
Not open for further replies.
So. Umm.. no1 has really clarified which kernel works the best for this. Shabby penguin? Chris41g control12, rc?? I just want one where EVERYTHING works..
Sent from my SPH-D710 using Android Central Forums
Re: [ROM][ICS][July 30, 2012] Android Open Kang Project [Stable 2
no kernel is perfect but control 12 is not too far from it. DK told me Shabby uses chris41 source so it has the same issues.
can i flash S3 dirty from S2? cache and dalvik cache only?
mmmm never tried, give it a shot I dont think it would cause too many problems at the most you have to clean wipe everything and flash s3 from scratch.
but I have no idea thats just my guess
Yes you can
DK I tried a CM9 nightly recently and I had no LOS and the kernel seem to work very well. However I really like your ROM more.. well a lot more lol
Is there a way we can make a zip of that cm9 kernel and flash it on S3 to see how it turns out?
Not sure of this is rom related or kernel but you tube won't play for me
It freezes up on video. I am using chris control 12 on s3.
So I had tegrak overclock installed and I unistalled it and rebooted
It is working now. Not sure of it was removing overer locking or reboot that made it work again
I tried going to shabbys nightlies goo.im page but goo.im is down yet again.
Shabbys nightlies are just chris41g's experimental builds. You can find his kernels and rooms on his personal site too if goo was down.
sent from my BAD A$$ Epic touch
Reactions: Dark_Knight2
Re: [ROM][ICS][Aug 18, 2012] Android Open Kang Project [Stable 3]
Download your Stable 3 build below
HFS /public/AOKP_DK_ICS_Stable/
This directory also contains the recommended kernels and modems posted on the OP!
FH13 Modem
Times Infinity Kernel
FF18 Repack Kernel
Enjoy, thanks to DK!
shabbypenguin's kernel doesn't read internal storage and errors out trying to access sd card and share's the same bugs as Chris41g's. reinstalled S3 and flashed chris41g's control12 which has been really good to me.
side note: S3 seems smother and a lil butterier. . . is it just me?
I flashed from the July 20 release after clearing cache/dalvik...won't see internal or external storage. When I enter settings menu for storage, it FC's.
Gotta do a full wipe for this one fellas.
Its the kernel causing those errors try chris control 12
Same here just put control 12 back on
Status
No members online now.
Dreamz
