[ROM][ICS][Aug 18, 2012] Android Open Kang Project [Stable 4]
Status
Not open for further replies.
Re: [ROM][ICS][Aug 18, 2012] Android Open Kang Project [Stable 3]
FF18_Repack_HighlyModified_AOKP.zip
Right?
II did and I had the reversed storage situation which is fine cause I changed to internal storage under settings but when I did that Apollo and android music don't see all my music files :(
Yeah and what the hell is a "control 12" and how is that related to any kernel in the OP?
I think that poster thought you were talking about the recommended kernel just a bit confusIon that's all
Oh, alright. Yeah all I want is to be able to see my internal/external storage... Info most surely is not in the OP...
OK download chris41g control 12 kernel below:
HFS /public/Chris41g_Kernels_E4GT/
agent make sure to clear cache and davlik after flashing, and once you boot if you cant see the storage you want go to settings --> storage then press the menu key --> storage configuration and check internal storage, then reboot.
Reactions: agentfazexx
Fixed the storage issue. Will report back on other issues that come up.
Gallery won't display anything on my SD card?
Reactions: deakelem
Status
heritagevine14
