[ROM][ICS][Aug 18, 2012] Android Open Kang Project [Stable 4]
Status
Not open for further replies.
Re: [ROM][ICS][Aug 18, 2012] Android Open Kang Project [Stable 3]
Oh I can easily fix that. Stand by. That was a mistake on my end.
Awesome thanks DK. I know it was an issue is a previous build I think like in one of the RC's of aokp ics. I guess its back :(
Just when I thought stable 2 was good, stable 3 comes by and whups butt. Awesome work dk2.
Sent from my SPH-D710 using Android Central Forums
Sucks I won't be able to flash that beauty till Sunday <\3
Never got it to work with the built in program but I always just use android wifi tether found on google code.
Ill upload it to my srvr so you can dl it. It works very well.
update:
I put the apk for wifi tether below, once you open it go to settings and change system profile to "epic 4g touch"
Enjoy!
HFS /public/apks/
Thanks... ;)
Argh! Can I flash stable 4 over stable 3 if just wipe dalvik and cache??
yup I just did, worked fine
do note that if you experience any issues no matter how small, try doing a clean wipe and flash s4 before reporting
Reactions: dante32278
I am not sure if anyone is experiencing this or not but has anyone had any keyboard issues? Like it stays like stuck and doesn't type anything else at times. Just when you back out of a message and back in is when the little bug goes away :(
Sent from my SPH-D710 using Tapatalk 2
Has anyone tried flashing this Rom on control 12
I did and it worked just as well as it did on all other builds
BUT
I re-flashed and stayed with the built in kernel and everything is great so far (storage, backlights, haptic, etc)
DK fixed the storage force close issue with this build 4
Status
ryzengames
