[ROM][ICS][Aug 18, 2012] Android Open Kang Project [Stable 4]
Status
Not open for further replies.
One thing to check regarding battery drain:
For whatever reason my screen was set to always max brightness by default. I could watch my battery drain as I browsed the Web or did anything really. I set it to auto and it has helped dramatically.
Sent from my SPH-D710 using Android Central Forums
Reactions: Dark_Knight2
Well Done. I used TI's M6 and must say this is smooth and a bit more snappy. Good Work. This will be my DD
Sent from my SPH-D710 using Xparent SkyBlue Tapatalk 2
I know DK is working on it but If anyone has any suggestions on how to get wifi working with the FF18 rebuild, im all ears! :)
Thanks
Yes they do. they were confirmed fixed on stable 4.
I just tried :/
I did a fresh install :/ back to ff18 auto root agat then calkulin. Dalvic and baterry stat fixed permissions flashed s4 kernel gapps modern dalvic and cache partition
Dk, have you thought of maybe using goo.im for hosting? I only ask because the auto md5 check is an amazing feature!
Sent from my SPH-D710 using Tapatalk 2
I will NEVER use goo.im cause about two weeks ago goo.im were doing "System Maintence" on there servers....THEY DELETED ALL HOSTED FILES. I might use mediafire or fileshare later on.
Reactions: deakelem
So is the FH18 flash able zip only flashable through CWM, or is it safe to flash it through TWRP?
Love the rom DK...it has been my daily driver since Stable 1, and by far is the best rom on the E4GT. I just wanted to give you a heads up that after the 1st of September i can dedicate my E4GT to testing out builds and tweaks if u need the help since my E4GT wont be my daily driver anymore. Much thanks
I am patiently waiting for jelly aokp. I prefer aokp ics to cm jellybean as it is. Aokp jelly is my phone's destiny! It's crosstraining in the mountains just getting ready! Got eye of the tiger playing and everything :p
-AOKP milestone 6 - FH13 Modem - Cobalt theme
Status
sahnyuakm
