[ROM][ICS][Aug 18, 2012] Android Open Kang Project [Stable 4]
Status
Not open for further replies.
Sounds good. Alright, I just saw a disclaimer about an EMMC bug. Where is there something for me to read to know how to avoid this and do you have a suggestion as far as a root/flash tutorial for the E4GT?
Follow my directions in the op and you wont brick. :)
Do you need to wipe b4 u flash a new modem?or can I just flash from twrp?
Sent from my SPH-D710 using Android Central Forums
So what themes are you guys using? I've got the jelly bean theme going right now. It's really sweet. Looking for some other good ones though.
-AOKP milestone 6 - FH13 Modem - 200dpi
I'm just using (and very much liking) the stock theme. I just came off CM9 Alpha 6 and this feels very much the same so its very familiar to me. On top of that, its very quick and responsive and I'm loving it.
And by the way, in response to my last post, my god is the battery life phenomenal! I'm loving this ROM and the modem.
I've so far only found one small bug. It is the musicfx setting in the audio settings. I don't know what it is, but as I was picking through the settings right after flashing like I always do, clicked on music effects and it automatically FC's.
I meant to delete that. Use dsp manager.
GPS wont get a lock, is anybody have the same problem or any suggestions?
Revert back to EL29 or FF18 get a solid gps lock then mobile odin (Apk is in my op) the EL26 kernel w/ cwm5 recovery...wipe data and cache then flash aokp s4 then flash gapps then reboot. You should get a solid lock then.
Yea no worries buddy. Its not something I'm ever going to use, I'm definitely not an audiophile, just something I noticed poking through the settings :-)
Sent from my Epic 4G Touch running DK2's AOKP Stable 4
Im running aokp milestone 6 and id like to check out stable 3. Any special directions i need to follow? Do i need to go back to stock first and then do the process in the op or.......?just want to make sure i don't mess anything up.
Sent from my GT-P7510 using Android Central Forums
Stable 4 you mean :P
No biggie. Ill get that is Stable 5.
DK Im loving stable 4 and havnt found any issues with it. When using the built in kernel my storage works fine (camera, file manager, etc can all see my internal storage) but any game or app that uses the internal storage force closes and im assuming its cause it cant access the proper files on my internal storage.
Its probably not an issue with the rom but the kernel, other than that !!!! :) :) :)
I flashed Stable 3, and it seemed super snappy, responsive, and generally awesome except for the SD cards not showing up. Then I flashed Stable 4 with the SD card fixes, and the whole interface seemed super laggy. I tried reflashing it and it had the same thing. Is there anything I could be missing that would cause the rom to be laggy like that? And yes, I read the OP :)
And thanks for this rom, I love the AOKP rom.
Really. This is a first. Have you tried redownloading and flashing again?
Status
Kenny Fluent
