[ROM][JB][WIP] CyanogenMod 10 for LG-P505/506
i flashed the catapault and im still having the same problems as before should i try to reflash it again?
setup wizard has stopped. settings has stopped. home dock doesnt work neither does the lock screen.
Did you factory restore/wipe data in the recovery before you flashed?
That sounds like you didn't...
Who's in the mood for some more Google Now?
And this time with working voice!
Special thanks to SilentStormer and Jonny_G at XDA for these APKs
I just made a few tiny changes and the flashable zip :p
EDIT: Might help if I actually gave the link....
http://dl.dropbox.com/u/56064156/CM10/Google Now With Voice.zip
EDIT Again: Sadly the darn voice still doesn't work...
i did the wipe and still settings stopped and the wizard setup also stopped. and the lock screen works sometimes. any ideas on how to fix?
edit: also no homescreen and home button doesnt work
Almost there with Google now. Voice seach still having issues. It seems to think I'm saying something even though im not and fails to recognize voice patterns to initialize search. Seems like it just needs minor tweaking.
That's in the ROM. No other voice recognition is working either. I'm starting to think that the voice recognition libraries aren't being included in the builds...
So has anybody resolved any of the Phoenix issues yet?
Sent from my LG-p505 using Android Central Forums
just the new build or the new build with gapps and catapalt?
edit: also do i have to erase data and cache before i flash anything?
You must wipe data and cache when flashing before flashing a rom.
Current Steps to flashing JB.
1. Flash Rom Reboot and Launch
2. Reboot (may need to remove battery) into recovery and flash Catapult Patch
3. Reboot into recovery and flash GAPPS for JB
I like taking extra steps just to be safe.
Flash the new build then catapult then gapps. If you need the links, just tell me
And no, no erasing anything since you are upgrading within the same OS version.
Only erase if you upgrade from 4.0 to 4.1 for example or 2.2 to 2.3
jafar
