[ROM][JB][WIP] CyanogenMod 10 for LG-P505/506
it works thank you. quick question how do you delete contacts or music?
To delete contacts: Open the People app. Open the contact you don't want. Press menu and select Delete
To delete music: Open a file browser. Find where the file is on your SD card. Delete the file
Reactions: s_box
Hey the Apollo app And the Google search tool at the top doesn't work
Sent from my LG-P506 using Android Central Forums
To fix Apollo: Press the menu button when at the home screen. Click manage apps. Go to All Apps. Open Apollo. Click Force stop. Then Clear data. Then it will work
As for Google Search bar, you need to flash the Google Now fix I uploaded. Here it is again:
http://dl.dropbox.com/u/56064156/CM10/Google Now With Voice.zip
Reactions: s_box
I think i just discovered a new bug, but i think that only happens with my phone, because i see that no one has reported it....
This happens when i connect my phone to the computer using the USB cable, the touchscreen just goes crazy and it doesn't recognizes when i touch it, if I unplug the cable the touchscreen goes normal again
FWI: i reported this a few posts back but i couldn't found the trigger, so now i'm posting it again
attaching a Logcat
attaching a Logcat
Thank you very much! I will investigate ASAP
@failed1234: I really have no clue what the heck is wrong with your setup... Everyone else's works. Are you using the ICS or JB GAPPS (pretty stupid of me to ask but just making sure ;) )
JB. I'll try again today. Maybe it was just an abnormality.
Sent from my LG-p505 using Android Central Forums
I can't get SuperSU to update its binaries. Installs fine and gets root permission from superuser.
I've also noticed that in Es File Explorer when I open a text file to view or edit with Es File Explorer's built-in text editor that I get a black screen with some red lines where some of the text is. Anyone else experience this ?
Think I've figured out my SuperSU problem. There is zero free space left in system. How is this possible?
The new 8/1 build installed great. I wiped everything, flashed rom, rebooted, flashed jb-gapps and everything seems to be working out of the box now (except for google now voice. hehe i can't wait for that). Looks like its really coming together rashed :) heres a logcat in case it helps, no particular reason. As far as internal storage, after flashing gapps i was using 81mb.
For now and future references every time I flash a new build do I have to flash the catapult and gapps also?
Just flash gapps. Or try reading the post seriously right above yours...
OK, now I wiped everything and then flashed the latest build and GApps. But the home button didn't work, along with the browser and lock screen. Also, I didn't get any sort of set up screen when I first booted up (It went straight to the home screen).
You really should reboot between flashes. Either reboot into the ROM or select 'Advanced' from CWM main menu and then select 'Reboot Recovery'.
I'm downloading the latest build now. Will check it to see if the launcher was included this time cause it wasn't included in the last build. It wouldn't hurt anything to install the Catapult patch even if it's included with the ROM tho.
I always do a factory reset. This wipes user data, cache, .android_secure, and sd-ext if you have one. Then I goto the 'Advanced' option in CWM main screen and choose 'Wipe Dalvic cache' and also 'Wipe battery stats'. Hopefully this may help.
abrakadabraham
