[ROM][JB][WIP] CyanogenMod 10 for LG-P505/506
I tried the new recovery. It boots fine for me. Couple things tho:
- Screen is really dim
- The overall size of everything, which was mentioned already. Because of this you still need to use the volume keys to navigate thru the choices :(
Haven't tried anything else other than browsing thru the menu options. You're making progress tho. And I do like this approach better than the other touch recovery I use. ;) :cool:
Did you wipe everything before you flashed it?
Sent from my Amazon Kindle Fire using Android Central Forums
No. Flashing a recovery is slightly different from flashing a ROM. No wipes required. Just a recovery reboot.
Boot into your CWM.
Choose 'Install from zip"
Choose 'Browse for zip", then select zip to flash, confirm selection
Once done flashing go back to CWM main menu.
Choose 'Advanced'
Choose 'Reboot Recovery' and you're done
Boot into your CWM.
Choose 'Advanced'
I'll try it again.
Edit: And it doesn't work. Again. I hate my phone.
Sent from my LG-p505 using Android Central Forums
I'll try it again.
This is what I did when I flashed a bad recovery. The recovery you flashed works you just cant see anything; well I hope its just this
1. If you don't have it, you need Rom Manager premium.
2. You need the working recovery you want to flash.
3. Flash the recovery through Rom Manager (its gonna prompt you to boot into recovery to finish flashing, just accept)
4. Phone is gonna boot into recovery and do its job, you just wont be able to see it. Just let the phone do its thing (don't press anything) and it will reboot itself automatically.
5. Boot back into recovery and check out your recovery.
That's what I did when I flashed a bad recovery. Right now I am using amonra. It has the color issues but I can see everything and it works perfect. Just temp until the new 505 recovery is done. Hope this helps anyone in need.
Sent from my LG-P505 using Android Central Forums
I'll try it again.
Don't hate your phone. It's not it's fault. Blame AT&T for giving up on it. ;)
There is one other way to flash a recovery and that is with fastboot. Fastboot is a utility program that comes with the Android SDK. If you have it I will explain in detail if you'd like.
Eh, I don't need the touch recovery. Oh, and Rashed, JB works now. Google now, too. Maps just keeps fc'ing.
Sent from my LG-P506 using Android Central Forums
Good. Is the phoenix version that stable? I haven't tried it yet, but I'm anxious to.
Has anyone tried video playback because I have amd y phone reboots every time I try to watch a video.
Sent from my LG-P506 using Tapatalk 2
Yep, it's pretty good. Actually, just use fix permissions in ROM Manager to stop fc'ing.
Yeah it's pretty stable, i'm using it currently ;) I won't be able to build as consistently because i have just started school and i really need to concentrate because i'm facing graduating late if i don't pass everything this year. I will build when i have the time though. :)
Just started? I'm still enjoying the beach right now. How old are you?
Well, this build is certainly an improvement, is more responsive and fast
Besides from that the bug that happens with my phone, the one that involves the touchscreen, i can say that is better, the problem is there, but at least now I can long press the items in the homescreen, but still does not recognize some of my touches...
Also the rom isn't mounting my ext2 partition so i can't use link2sd, but you can move apps normally
I had that problem too. I think it's cause JB only recognizing ext-3 partitions. I had an ext-4 partition that JB wouldn't mount. I repartitioned my sdcard using the new Thrive recovery whose only option is ext-3, and Link2SD let me create a mount script for it. :D Workin fine now.
WONDERFUL!!!
I have a new build I'm tweaking. Fixes camera I think.
And Oathkeeper, get on GTalk :p
*cries....* NOOO No fixed camera... yet
Anyway for the P506 the link should be the same, but if you don't have it, here it is again:
Download P506:
http://dl.dropbox.com/u/56064156/CM10/P506/cm-10-20120801-UNOFFICIAL-p506.zip
And for the P505, it will be up tomorrow
Download P505:
And here is my first for the P500:
Download P500:
http://dl.dropbox.com/u/56064156/CM10/P500/cm-10-20120802-UNOFFICIAL-p500.zip
And a CWM for the Phoenix and Thrive. NOT Touch and it should fix everything. Will fix brightness tomorrow
Download CWM:
http://dl.dropbox.com/u/56064156/CM10/GenericCWM.zip
i think i will play with the new recovery. i can wait another day for the jb update :)
If the search button does not work, press either menu or home a lot until you see back button disabled. Then the search button will work.
Oh, an for future reference: do we need to flash the baseband fix every time we update, or just once?
Sent from my LG-P506 (Not really) using Android Central Forums
When I needed to flash the old baseband fix, I think it was almost every time. If I were you I would do it every time because it doesn't hurt and it takes like two seconds to do it.
MO Shm0
