[ROM][REPO]{RGH135} {VM701}{LG55C} CyanogenMod7
Okay... little update. I've fixed the VM branding and I've fixed the wake/sleep issues. However the screen on animations not working at least it will wake from being asleep. I'm still working on the radio. We'll see... I really want to get this working... grrrrrr
i have full faith in you jcole20. is it entirely possible the radio.img would be a bit similar to the one in the gelato rom or even stock?
In theory if I can pull the radio.img I can flash it on top of the CM7 build and it will have a working Radio. I've been trying to dd it but I think I need to dump_image to pull it. Thats not the only issue though, and it may be something inside the /system/lib's or /system/etc folder I don't know. I've never fixed a radio issue. But the other big issue is with the Sound. We have absolutely no sound in the rom. That needs to be corrected as well. I've worked hard and I've got a bootable build with some theme engine themes, and the market implemented. But accounts&sync seems to be an issue as well. I don't know if its because of the baseband being nulled or not, but it's not letting me put in account info on wifi. Lol, this is ridiculously frustrating. Here's the link to my current state at the moment. You can flash this on your slider the keymapping will just be different, but go ahead and check the wake/sleep and tell me if its working for you all.
Click Here to Download CM7
Again this is for the Q but it will boot on the Slider... our kernel base is the same. Your keymapping will just be off. If I get the Radio and all figured out I'll get it working on the Slider builds as well. This is so aggravating.
Edit: The radio is going to not change at all from stock to CM7... it can't change. Thats the issue here, the radio configuration somewhere is either not activating or its not the same. And I really don't have any experience activating a radio. I'm doing as much research as I can trying to figure this out.
I heard before that not all of the libs files were ported over correctly, they were left incomplete. That could be one of the reasons sound isn't working at all. I don't have service on my Slider anymore, just switched back to the OV as my daily phone. Being away from CM7 for so long was a pain.
Sent from my LG-VM670 running quattrimus AOKP alpha10 using Tapatalk
Well there are lib files that control the radio too. I've tried figuring out what those are and pushing them in, and still no radio... this is getting to be ridiculous.
i have no problem with the waking up sleeping power function. that's fine.
no camera.
no radio.
Wake/Sleep seems to be working now for my... Slider ^.^;; (got a little impatient and wanted to try some more CM7 lol) Sorry I cant help anymore then just trying stuff out
I can probably fix the camera and maybe the accelerometer... the radio i really don't know. Wake/Sleep is now working which is a plus. This is hard stuff man... I've not been on android long enough to fix all of this lol. I'm really at a point of giving up on it cause theres a lot here to be fixed.
Yeah, I'm sorry you all... but I give up at this point. Someone needs to go through the services.jar and fix the code in it to get the screen on and off animations working again. But it shouldn't lock up on wake anymore. I don't know what to tell you all. This is a big task and I don't think I can correct everything thats wrong with this.
Lol yeah I'm good friends with larry, but I haven't been able to get in touch with him in over a week. Idk what to do at this point. The lib files controlling the radio when replaced with working files won't allow the rom to boot. Meaning the .so files need to be recompiled using the vendor source. (At least this is what I'm thinking.) I have tried everything I know to do and I can't get a working radio or sound. I'm sorry. We need more people working on this. Ill attempt a fresh compile of cm7 tomorrow or this weekend and try to merge the source myself. Though I'm fairly confident in rgh's knowledge and I'm sure his builds are done correctly. The keymapping is way off on the physical keyboard. I'm thinking bobzhomes repos are lacking... but don't quote me on that.
Sent from my LGL55C using Tapatalk
I disagree... the only plus is the sound.so's are working. But that cm9 has the same issues and that added circle mouse pointer thing... which imo is really annoying.
Do no devs own the Slider? I might be willing to donate mine so you guys can have CM7. Not like I'm using it anymore.
so i just 'atttempted' to flash cm7. boot loop. so i flashed gellato. i hope yall get this working because i had cm on my ov and it was ballin af' so yeah.
do a wipe data factory reset then wipe dalvik then flash it... but yeah i really do want this working
Will someone with a slider do me a favor... take a stock rom and navigate to /system/etc and upload the apns-config.xml thats in that folder for me. I'm going to need that file to get the radio working on this for you all. I'm still trying to find the other dependencies but I know that file in the CM7 Rom is all wrong. Thank you...
camran
