[ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
Status
Not open for further replies.
Re: [ROM][JB][08/21/2012] Jellybro CM10 [Nightly 4]
Deleted. Double post, sorry for that...
I have an irrelevant question to the ROM. Doesn't the account gets backed up automatic on the Google dashboard on AOSP ROMs?
I mean, it asks me if I want to backup my phone and then if I want to restore it on my account. But whatever I do, it never worked. They said, it is a problem with the TouchWiz-based ROMs, but I thought since we are using an AOSP ROM, we will have this privilege. My friend with the Nexus S has everything backed up. The system settings, the WiFi passwords and of course the Apps...
So I gave this a whirl and....wasn't for me. It felt choppy, like project butter wasn't even thought of yet lol (not attacking) I followed OP to a T. I guess I could have let the ROM "settle" but I don't really think code has to settle.
Maybe I'm just the unlucky one lol. And WiFi works perfect.
Sent from my EPIC 4G Touch!
Hmmmm.... try reflashing. And did you factory reset or did you just flash over your previous ROM.
Edit: You might try wiping cache and dalvik cache as well.
Sent from my SPH-D710 using Android Central Forums
Sorry it didnt work out.
one last thing, say if I want to go back to an ICS rom that's rooted what do I have to do? Thanks! or is the recovery included safe for me to just flash it?
CM is not really AOSP. It is compiled using AOSP source but the CM team hack the hell out of it. Some stuff is removed and some new features added. With that said you are comparing pure AOSP Nexus Device to a hacked out ET4G running CM10. Make sense?
Reactions: ahmadshawki
Would it be better to go back to el26 then flash Sbrissens_JB_Odin_Restore.tar in mobile odin then flash nighly 4 itself, etc?
On Nightly 4 test build shared earlier with JB 07/26 from Goo.im and CM10. Pretty smooth and no issues till now.
I am on the kernel that comes with the ROM and FH13 modem.
Will have to test the battery with my bluetooth headphones on for the next 2 hrs.
Sent from my SPH-D710 using Tapatalk 2
How would I go about returning to AOKP or an TW ICS ROM?
I haven't had any airplane mode so far. Did notice that if you have 4G on and turn on WiFi that 4G stays on and causes wake lock
Agreed that it's off topic, but the restore worked once for me on a new ROM, but only once. I'd like to know how this works too.
I did that a couple of times and according to my experience, you have two options:
1. Flash directly from the CWM included in the JB ROM. I did it and the kernel is replaced with the one in AOKP.
2. Flash a safe recovery like AGAT ( the most one I used) and then reboot into recovery. Then flash whatever you want. (Also tried that a couple of times and worked like a charm).
Hope this helps...
Reactions: DPtheKid
Also I noticed a new setting I haven't seen before. WiFi idle timeout time it is set for 15 min but it is grayed out and I can't change it
Status
No members online now.
kevin_bkt
