[ROM]Stock ED01 Rooted/ED01 Debloated/Debinged
Awesome wrk adrynalyne this is awesome wrk as always... Im hardly gona get 2 test this deodexed tho.cuz nitro got debloated ED01 comin out in an hr or so he says so i wnt have time 2 tell if I get SOD prob
I flashed over top of Nitroglycerines ROM without wiping data, but I wiped dalvik and partition 2x each and didn't have to reload anything. Running smooth as silk and getting ready to start theming.
Is that rom based off of EB01. And did you just flash it in cwm.
Cwm keeps giving me an error saying the signature is invalid. Its this because I downloaded over 3g
Which ROM? Nitro's is based off of EC01, while Adrynalyne's is based off of ED01. Most people are pretty sure that both of those systems (EC01, and ED01) are the same. Just for reference, I haven't ODIN'd anything since the EC01 radio came out.
I'm pretty sure I need to clear data and such, as I am seeing ghosts of old ROM's in my current setup. I.E. my current setup doesn't allow for keeping the screen on while charging, yet it stays on.
I was running SuperClean 2.9.2 and reverted back to stock this morning but having problems as it's telling me that no new software is found. If I go back to 2.9.2, do I flash this new ED01 through CWM once I put it on the SD card or is this flashed through ODIN?
I was able to load this zip on top of the ED01 update. It certainly gets rid of all the junk. All works good so far.
That was fast!!! Thanks for all the great work. I'm looking forward to your next Super Clean hopefully.
You can flash it through CWM on top of SC 2.9.2. You may want to ODIN the EC01 radio though. It has made my GPS performance go through the roof.
Reactions: marteagajr75
Ok, I have to ask, if I go back to dl09, ota ea28, ota ed01, then flash d/d, dbinged, that will have ed01 radio and kernel, correct?
Reactions: nbelshaw
THis is what I want to know too! Gosh I really want to move ahead on getting ED01, but no one has answered these types of questions.
I think I am right. ALL HECK WITH IT, I will just do it later tonight. I am sure that is what will be the case. Just Odin back to stock do the OTA and Flash this Rom. I am sure that will give me the ED01 Radio.
I was about to do it and then I was hearing on the Problems thread that the Camera wasn't working and that the battery was bad. But it probably has something to do with the bloat that they have. Maybe with it deodexed/debloated, it will be bad @$$! BUT GOOD LUCK! Report back is all I ask.
this is the error i get
--Install from package...
Finding update package...
Opening update package...
Verifying update package...
E: failed to verify whole-file signature
E: signature verification failed
Installation aborted.
Jklawy
